Vortech sc 3.6 or 3.8
Showtimepat
Teki1975@
Patrick
I have a Vortech v3 jt on a 2018 s550 an I’m stuck with 91 oct in my area, am I able to run the 3.6 with no additives or do I need to run the 3.8?
larr12
Alberto
2020 Mustang PP1
1. Ask your Tuner
2. Ask @beefcake for his advise and any supporting mods you might need.
beefcake
Bethel
2018 Ford Mustang
i personally would run a 3.8 on 91... unless your adding octabe booster to each tank
illadvised
San Diego
Brian Spilner
2015 GT - 6R80 - Paxton 2200SL
I am stuck on 91 also. My last mustang was a Kenne Bell, they said I could swap to a smaller pulley without a tune as long as I had octane booster in the tank. So I would swap back and forth between pulleys
Is that the case with these centri kits? Can I swap pulleys with just octane booster or would I need to retune also
beefcake
Bethel
2018 Ford Mustang
you would want the tuner to at least look at logs, if you add a can of octanium to each tank you will proably be fine 1 pulley down, but again, have tuner check fueling
