You can't really compare your traditional Ford engine with the VOODOO. Your other Fords did not have a flat plane crank. This allows the engine to rev to the mind blowing 8250 RPM. The problem is the VOODOO has a lot of of shaking going on due to the engine design. This is why the oil filters needed to be torqued to 16-18 ft lbs. All flat plane cranks have NVH problems. On the track that is to be expected. Over the life of a street engine? Time will tell.Probably the Voodoo will last on average longer than any of us will keep the cars. I have a couple Fords with well over 200,000 miles on them. I can't think of any reason the Voodoo wouldn't last that long. I have about 19,000 miles on mine. Not many so far.
I think that's a bit overblown with engines that aren't FI'ed. It just has high visibility. I'm not worried about mine one bit.The other problem I see with long term reliability is the cast OPG gear. There have been multiple failures on the Coyote which uses the same cast OPG as the VOODOO. The Coyote has much less pressure on the OPG so it sometimes felt like a ticking time bomb to me.
Never happening. I'd be more worried about a metal one that was poorly treated or something from expansion and contraction. We're going to be fine.As long as something like plastic intake manifold don't crack 3 years out.
I don't own a vehicle with a 4 cylinder engine, but those have a FPC. Ford makes a crap ton of FPC engines. And I sure as heck think I can compare several different engines made by the same company using some of the same people and processes to develop and test those engines. Explain to me why you think that Ford forgot to test the Voodoo.You can't really compare your traditional Ford engine with the VOODOO. Your other Fords did not have a flat plane crank. This allows the engine to rev to the mind blowing 8250 RPM. The problem is the VOODOO has a lot of of shaking going on due to the engine design. This is why the oil filters needed to be torqued to 16-18 ft lbs. All flat plane cranks have NVH problems. On the track that is to be expected. Over the life of a street engine? Time will tell.
Welcome back!You can't really compare your traditional Ford engine with the VOODOO. Your other Fords did not have a flat plane crank. This allows the engine to rev to the mind blowing 8250 RPM. The problem is the VOODOO has a lot of of shaking going on due to the engine design. This is why the oil filters needed to be torqued to 16-18 ft lbs. All flat plane cranks have NVH problems. On the track that is to be expected. Over the life of a street engine? Time will tell.
Comparing a 4 cylinder flat plane engine to a V8 engine is not apples to apples. All you have to do is google inherent flaws in V8, V10, V12 flat plane and you will see NVH is a major problem and has been for years. For packaging reasons, Ford could not use dual intakes and or equal length headers or a light weight crank. All of this again causes NVH.I don't own a vehicle with a 4 cylinder engine, but those have a FPC. Ford makes a crap ton of FPC engines. And I sure as heck think I can compare several different engines made by the same company using some of the same people and processes to develop and test those engines. Explain to me why you think that Ford forgot to test the Voodoo.
NVH isn't a "problem". It's a characteristic. If I valued squishy and quiet luxury over all else, maybe NVH would be a "problem" for me. But I don't and it isn't.
I just plain disagree with you on the OPG thing as well.
The OPG is NOT cast per se. It is made from specially blended powdered metal with very precise properties for close tolerances and excellent wear and durability characteristics. That is how this pump makes big oil pressure.You can't really compare your traditional Ford engine with the VOODOO. Your other Fords did not have a flat plane crank. This allows the engine to rev to the mind blowing 8250 RPM. The problem is the VOODOO has a lot of of shaking going on due to the engine design. This is why the oil filters needed to be torqued to 16-18 ft lbs. All flat plane cranks have NVH problems. On the track that is to be expected. Over the life of a street engine? Time will tell.
