Viking crusader rear shocks
Drsmith33
Cincinnati
Donald
2018 Mustang gt
Just installed the Viking crusader AM rear shocks on my 2018 and now I’m getting much much more noise coming from the rear of the car. I know they say to expect it because of the bushings used but I just want to make sure everything is ok.
NastyPumpkin
Michigan
2018 Boosted Mustang GT
I have the same shocks on my 18, no noise. I would check all nuts and bolts and make sure they are all tight. Set the Compression at 4 & Rebound at 7 for the street. C-8 & R-11 at the strip.
Drsmith33
Drsmith33
Cincinnati
Donald
2018 Mustang gt
I’ve rechecked everything again. Everything is torqued to spec and installed right. I’ve messed around with the compression and rebound. The noise is seriously bad. Over the slightest bumps it makes many loud thuds and popping noises. If it’s going to stay like this then I’m just going to take them off.
Burkey
Australia
Are you using the OEM mounts?
Mine were completely silent until I added the BMR mounts. The noise was just too stupid for a daily car.
Drsmith33
Drsmith33
Cincinnati
Donald
2018 Mustang gt
The shocks I ordered came with mounts on them already
Burkey
Australia
Burkey
Australia
Drsmith33
Drsmith33
Cincinnati
Donald
2018 Mustang gt
I know! Lol I ordered them from lethal performance and the image didn’t have that mount of them. No idea why it came on. A YouTube installed them on his 18 and they were the exact same way.
Burkey
Australia
If you can ditch that mount and use the stocker, that might help. Hard to say for sure.
Drsmith33
Drsmith33
Cincinnati
Donald
2018 Mustang gt
I’m going to give that a try. Thanks for the advise!
Drsmith33
Drsmith33
Cincinnati
Donald
2018 Mustang gt
So I talked to Viking today and they said the mounts that came on my shocks are the t bar mounts and they started using those on the newer models because they are stronger than the other mounts. They did say however, that a downfall of using them are that they create much more noise than other mounts. They said people were breaking the stock mounts so they switched to these. I’m just going to continue using them and see what happens. I don’t daily drive the car, just some drag racing here and there. Not too fun daily driving 900whp lol
Burkey
Australia
That’s precisely why I added the BMR mounts. The damper settings required for a manual are BRUTAL. Likelihood of punching a hole in the stock mounts is pretty high IMO.
On the road, with softer damping, I think it’s highly unlikely that the stock mount would fail.
YMMV of course.
