Vibration issue while driving
BoostedProf
King of Prussia, Pennsylvania
Lewis
2016 Ford Mustang Shelby GT350
I've been dealing with a vibration issue for about a month now. Need help diagnosing where it might be coming from. It happens mostly when I drive between 20mph and 40mph. If I go faster it goes away (but I just think its vibrating faster since I'm moving faster). It does not do it in neutral or at idle. If I drive up to 40 and push the clutch in, it goes away. Doesn't have tire flat spots or bent wheels (wheels are balanced).
So far the car has had its wheels balanced, front lower control arm replaced, driveshaft bolts replaced, and an alignment. Driveshaft bolts were replaced since I saw that they were loose/backing out. I assume (after I looked at the history) that the rear differential was replaced from the previous owner and the bolts were put in but not torqued correctly.
I also saw something about the tone ring TSB recently but after reading it and seeing other people's diagnosing, I don't believe this is the issue.
Best thing I can relate to the vibration is when you drive on a rumble strip on the highway. I have no idea what is could be. Any ideas or has anyone experienced this? NOTE: Car is still under warranty for another year.
CorralesR
Corrales NM/ Las Vegas NV.
2017 GT350R HR067,2018 GT350 J3225, 2003 Saleen S281SC , 2024 Bronco BD 4DR SAS
I assume no check engine lights? Does it matter what gear you are in while driving 40 mph? Just curious if it's engine speed related. Does it change if you are in 2nd gear going 40 vs 3rd or 4th gear? I'd check the rear hub bearing on both sides. They can rumble like that and they are failry common on the S550s. Although if the vibrations go away at 40 with the clutch pushed in then maybe not the hub bearings.
BoostedProf
BoostedProf
Lewis
No lights or codes. Doesn't matter what gear im in and it happens after 20mph. It doesnt go away at 40mph, it goes away if I push in the clutch while moving around that speed. Rear wheel bearings are good.
CorralesR
Hmm. Does it get worse under a load or hard acceleration vs light acceleration? I'm wondering about pinion bearing in the rear differential or maybe output shaft bearing in the transmission.
CANTWN4LSN
northwest
2017 GT350
Do you know why the rear differential was replaced? Was it perhaps related to the same issue? Who replaced it and was it done properly or have you checked with that facility?
Inthehighdesert
NM
Charlie
You may try indexing the driveshaft. It’s not as common as it use to be on older vehicles but there are occassions it does help.
BoostedProf
BoostedProf
Lewis
Does that involve taking it to a shop that specializes in that? I have a warranty on the car so I'd want it covered if servive needed to be performed
NTXChris
North Texas
2019 PP1 GT
Have you driven over any gravel lately? I had a similar issue with my car after driving over a temporary road repair. A rock got kicked up by one of my front tires and lodged in the transmission mount. Made it feel like the car was going to vibrate apart, along with some gear noise when accelerating.
2016 Mustang GT PP w/ Voodoo
If it doesnt vibrates with the clutch in and its still in gear, that pretty much eliminates everything behind the clutch plate, including the trans mount and driveshaft. All that stuff is still spinning in that scenario and if those parts were the issue they should still be buzzing. If it still vibrates in neutral with the clutch in that would be an interesting detail, but anyway.
How old are the motor mounts? I’d check those next. Anything else in the engine bay that could be rubbing? Any aftermarket intakes or exhaust bits? Catch cans, etc?
Also try holding the RPMs up while pushing in the clutch and see if it still vibrates (normally clutch in would have the RPMs dropping to idle)
Inthehighdesert
NM
Charlie
No you’re basically just pulling the driveshaft and rotating it 180 degrees and reinstalling it. There’s some pretty decent tutorials on youtube. Worst part without a lift is getting the car jacked up on all four corners. It’s pretty simple.
BoostedProf
BoostedProf
Lewis
Not to my knowledge, no. But that might be a good place to look. I know my tires kick up rocks all the time.
BoostedProf
BoostedProf
Lewis
So it doesn't vibrate at all in neutral or at idle. It does it under load. Once I hit 20 it starts to do it but if I push the clutch in, it stops. Even if I push the clutch in and rev it, it still doesn't vibrate. I've noticed it gets worse as the car warms up. Car is a 2016 so the mounts I assume are 10 years old. I think if it was the mounts, it would vibrate regardless if I was moving or not. It doesn't. Nothing rubbing to what I can see.
Postal Bob
Long Island, NY
Bob
2019 Shelby GT350
Did you look at the exhaust system, particularly the hangers? Many instances of them breaking off.
Skye
ā‰ˆ39N
"Skye" Mach1 N2144
Associated with the Voodoo and the exhaust are two dampers. They are there to lessen the effect of any engine harmonics.
While other ideas are being checked out, it's something else to make a quick look of next time the car is on a lift. There should be one on each side, firmly attached.
Edit,
The differential replacement interests me. Usually it's individual bits like a seal, ring or bearing that's replaced, not an entire assembly.
If it was a dealer and you know the one that replaced it, I'd reach out and ask for a reading of the invoice for the customer, Service Advisor and mechanic comments. Maybe it'll make you think, "Hmm...". Or it might give confidence this is a new and unrelated problem.
