Jmeo
You said member ;)
- May 28, 2014
- Massachusetts
- Jaime
- 2020 GT500, 2023 F150 Raptor
- Vehicle Showcase
- 2
For those reading who have the Viking Shocks, I recommend installing bump-stops.
They are somewhat tricky to get over the top of the Viking Shafts. You can simply unthread the upper portion of the Viking, put the stop on, and re-attach the upper portion - or you can slide the stop over the shaft (this is a tight fit)
As for the bump stop itself, it is easiest to use the following bump-stop part # when using the Viking Shocks.
FR3C-5K570-A (The A part # has a larger top ID)
If you are also lowered, I recommend trimming the lower portion of the rear stop approximately 3/4".
I am working with Viking on a shaft design that makes the Bump Stop install easier, as well as some different shock bodies to help prevent bottoming out based on various ride heights. It is looking like it will be about 5-6 weeks before these are available.
Kelly,
Should I order the bump stops for the soon to be released Vikings? Or will they not need the bump stop with the redesign?
Also, will the rattling be addressed as well?
Oh, and if I should get the bump stops should I be using the part # you provided or is there some question if it should be an A or B?
Thank you,
Jaime
