TT - oil scavenge pump mounting
baevid
Houston
2015 Mustang GT
For those with a low/mid-mount turbo setup and drag k-member, where have you found to be the ideal spot to mount the oil scavenge pump? It’s one of the last things i need to finish buttoning up my car.
Cordero1
Kansas
Vic
2021 Mustang
baevid
Houston
2015 Mustang GT
Hmm alright, looks like just finding a good spot to mount it around the front frame/bumper area with a bracket. I was mocking up a few spots but then I wasn't sure if the pump had to be at certain angles or had to be level/above the oil pan for drainage and residual oil.
The shop had originally mounted the pump a bit further back in an area that was way too low to the ground so I told them I wanted it moved since there's no way it could clear normal things on a daily drive. Somewhere up front where it's more protected by the k-member obviously makes more sense.
Cordero1
Kansas
Vic
2021 Mustang
Yeah this was the only thread I could remember seeing someone mount one.
illtal
Aldo Mounts his somewhere near the turbos. I think it would be nice if someone would make a single stage dry bracket ah la hellion to syphon oil
