JAJ
- Apr 9, 2016
- Vancouver BC
- 2016 GT350 Track Pack
You were within a hair's breadth of getting fluid coming out - it might have taken another 3 or 4 ounces, but it was pretty much full.Just changed out the trans and diff fluids yesterday in a 2016 Tech pack (i.e., no coolers).
Quick question on capacities - when filling the transmission, I added about 2.75 quarts (Ford capacity says 2.5 quarts), but didn't feel fluid using my pinky in the fill hole. Most instructions I have seen recommend filling until fluid starts coming out of the fill hole. I stopped filling at 2.75 quarts since I didn't want to overfill.
Car was almost level (~ 0.25" delta between front and back using a level under the rocker panel area), so I'm not sure why fluid wasn't weeping out of the fill hole.
Maybe the jacking rail isn't the best datum for determining if the vehicle is level? jack stands were situated at the extreme ends of a BMR full length rail, so I don't think the rail was deflecting.
Any thoughts? Note that the old trans fluid wasn't visibly discolored, but the diff fluid seemed very dirty. I've got ~ 10k miles.
The trans fluid comes out looking good on the first change, but if you let it sit in the drain container for a while, you'll find lots of junk settling to the bottom. Some's black, some's shiny and there's quite a bit of both. The diff fluid, on the other hand, comes out looking really, really used. I've changed my diff fluid twice now and it gets better every time.
