Transmission fluid leak?
wingnutt
@FL410
michael
350R Procharged w/P1X
It appears the black o-ring on the trans cooler line is not fully seated. That fastener needs to be loosen and the o-ring reseated. It may have a bent cooler line bracket and that is why the o-ring is exposed. That is what I see in your photos.
well, not really…you are more than likely seeing the backing rings and not the seal 😉
matthewr87
matthewr87
2018 GT350
Welp.....I knew this was going to turn into a saga. They replaced the cracked AC line, pulled vacuum, and then another line coming out of the compressor failed after 10 mins.......
matthewr87
matthewr87
2018 GT350
And they confirmed that the PremiumCare ESP doesn't cover the transmission cooler line seal. Which is odd. I was mistaken before when I said that "transmission coolers" are excluded. That does not apply to PremiumCare. So I have no idea why they aren't covering that leak. Unless they consider it a wear and tear item, since wear and tear items are excluded from PremiumCare.
