Transmission Fluid Change
geep81
Cleveland OH
2020 GT Premium
I recently at 4.5 years and 33k miles changed the stock fluid to BG Synchro Shift II.
Immediately noticed positive change. Less clunking into gear and it just slides in easier.
My factory fill was also higher than what it said to add as the replacement, which I wonder could cause any issues like lockout/grinding?
Anyway just wanted to chime in very happy with the BG product.
Coosawjack
Beaufort, SC
Jack
2022 Mustang GT Convertible
My 2022 GT factory fill was over the fill plug and ran out a little but I don't think it hurts a thing??
I changed mine last weekend to Red Line DCTF which I found to be better than BG Syncro II in my 2014 GT....just a little better. In my 2022 GT it seems a bit smoother than OEM but not NIGHT AND DAY........my main complaint with 2014 OEM was cold shifting Winter......3rd would nibble the first few shifts but OK when it warmed up or circulated a bit!!
Seems like Ford has improved their OEM Fluid but the Red Line seems a little smoother plus I installed a magnetic drain plug!!
I would doubt fluid and fill would help 3rd gear lockout but I'm sure others will chime in on the subject??
Good Luck!!
markayash
atlanta
Marc
2021 Mustang
Ford changed mine with the BG and I noticed the trans temps were cooler.
HKusp
Hampton, Md.
Jason
I did the BG Sychro-shift II a few thousand miles ago at about 49K. I noticed a big difference from the stock 2018 fluid. Buttery smooth.
markayash
atlanta
Marc
2021 Mustang
I am not a huge additive person especially to CVT's but I added a bottle of BG CVT conditioner to my wife Rogue and the CVT is quieter. Already had drained replaced 5 quarts before and shifted better but always had a whine that bothered me.
So decided to try it and was shocked it helped, they claim it reconditions the old fluid.
They are known to have CVT issues so trying to keep it alive and happy.
Coosawjack
Beaufort, SC
Jack
Update: I took a 70+ mile ride through the BEAUTIFUL SC Lowcountry today.......81* and just right for a Top Down ride......my shifts are much smoother with the Red Line DCTF and it was very easy to slide from 4th to 3rd when going to 5th......never happened before so it really is less notchy!!
Stay Tuned......we'll see if it's any different after a few hundred more miles??
RiotfunK
mass
Binx
22 mustang GT Premium PP1 Manual
Motul DCTF-Meets ford spec and is night and day difference. No more nibble, crunchy feeling when shifting. My cold shifts now feel better than the warmed up shifts on the OEM fluid. Granted I changed to MGW shifter, Stainless clutch line and the Motul DCTF at same time. But this thing is such a joy to row the gears in now.
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
Just placed my order.
It appears here that replacing the fluid with anything is better than the factory fill, LOL..
geep81
geep81
Cleveland OH
2020 GT Premium
I decided to use BG instead of Motul because data on Motul is newer and BG has been used for the entire time the MT-82 is out. I'm no expert, just decided I liked the idea of the longer track record one in my daily driver.
cerbomark
TN
Did the change today. The rear took both quarts. Nothing overflowed. Took the top plug out again after a ride and still nothing.
The trans used everything minus the supplied cup to measure exactly what's supposed to be left . Car only had 19K but I ve done all the fluids (other than coolant ) since I purchased it so I m all good now.
Diff plugs.
cerbomark
TN
BTW, I never asked, old fluid from trans had some gold metallic fine particles. Magnetic did not pick them up. Someone told me that just a coating that was on parts? Thanks.
coyote550
NY/NJ
Alex
2016 Mustang GT Premium 6MT PP1; 2020 BMW X3 M40i
Seeing some fine metal particles is normal. There are bronze components in the trans which look a lot like gold. Also, bronze is not magnetic.
cerbomark
TN
is that a wear thing or a coating as someone said? Decent amount.
cerbomark
TN
disregard the inside but look at the edge (rest of pan had other contamination not related). Gold. Trans working fine. Wish I had have cleaned out pan before hand.
coyote550
NY/NJ
Alex
I think its just normal wear and tear. Looks almost salt like in size. If you had pieces that you can actually pick up with your fingers, then I would be concerned. Here's an example.
