Traction Control Question
RoadCone
Ohio
2016 Competition Orange PP
I have a 2016 GT PP premium. I went to the track Saturday, put the toggle switch to track mode. I started my burnout and the car just wanted to bog down rather that burn out. In track mode, is advance-track still on?
I don't think I was pressing the brakes to hard. Also when I attempted line lock, it stated option not available.
Can you also use Line lock with Launch Control off?
I did have launch control off while trying to do a burnout also.
Thanks for your advance guys!
melwff
Danbury,CT
2021 Mach 1 M2486
the owners manual lists what is required for Line Lock, Launch Control being ON is not one of the prerequisites.
The vehicle is on a level surface.
• The engine is running.
• The vehicle is traveling less than 25
mph (40 km/h).
• Selectable Drive Mode is not in wet
mode (if equipped).
• There are no electronic stability control
faults.
Advancetrac is off in track mode
RoadCone
RoadCone
Ohio
If advance track is off in track mode, that isn't the problem. Thanks for the info.
Guess I was too hard on the brakes.
Jay-rod427
Kansas
2016 GT C/S
Advance track is NOT off in track mode, it is just severely limited on what it can stop. Track mode does disable traction control though. Two different things btw.
RoadCone
RoadCone
Ohio
Would it stop the gradually stop the burnout?
Tommy V
Brookly park Md
Tommy
Yes it would,clutch protection would too.
RoadCone
RoadCone
Ohio
Thank you. Asked Lund and they said clutch protection is off in all their tunes.
jhatley7
2016 White GT PP, 2022 F350
May be driver error but I can't do a burnout in my car either without line lock. Bogs out and ties to stall. All nannies turned off, at the track with my skinnies up front.
RoadCone
RoadCone
Ohio
I feel a little better now, at least I'm not the only one. Went home and played with switching advance track off and practiced turning line lock on. I should be ready for it next time.
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
why would you not just use line lock and save you brakes? its super easy to use unless you want to burn out longer than 15 sec i guess lol
RoadCone
RoadCone
Ohio
I tried once. Didn't work because I didn't know what I was doing, had never used it before.
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
did take me 2 times to figure out but after you get it then its simple..
zanGTA
Garda Lake (IT)
Mustang GT Premium 2015
Advance track is On in track mode. To turn off everything you must press the brake and traction control button for 10 seconds, wait a confirmation message and press ok then.
