track & summer tires
vincentjm
Switzerland
Vincent
'15 Mustang GT PP
Hi guys!
I know this question has been asked a million times already, buy anyways:
I'm heading to the Nurburgring in 2 weeks and was looking to get some nice track tires that are also dailyable (for the drive to and from the track). Stock PP wheels.
Was looking at the Potenza RE-71r, maybe even Toyo R888r's. Or Firestone Indy 500's (more dailyable)?
Would love to hear some advice from some track guys. Also, 255/35, 275/35? Or what dimensions would be ideal?
Cheers,
Vincent
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
PS4S, PSS or Conti ECS, as well as the Indy 500, in that order. RE71R are a streetable track tire and will be fairly poor in the rain and wear quickly. Also, on the ring they'll overheat quickly. You may also consider the Hankook R-S4.
  • Like
Reactions: kz
vincentjm
vincentjm
Switzerland
Vincent
'15 Mustang GT PP
i was thinking of getting dedicated track wheels (probably apex wheels) with re-71r’s. I can’t afford michelins lol. they’re really expensive here. the ECS look good, but not the biggest fan of how they look (don’t judge me haha)
BmacIL
Enginerd
Naperville, IL
Dedicated track wheels are a great idea, but RE71R are a time trial and autocross tire. They're designed to heat up very quickly. I love them for what I do, but wouldn't recommend them to you for what you're doing. Hankook R-S4 would be a good track tire choice that is very durable and still quicker than the Michelins and Conti. You could also do Nitto NT01.
vincentjm
vincentjm
Switzerland
Vincent
'15 Mustang GT PP
I’d go with Nitto in a heartbeat but they’re not available anywhere in Europe unfortunately. Hancook RS4 sound great so far. How are the RE71R for spirited driving/shorter track days in good weather?
BmacIL
Enginerd
Naperville, IL
They're great, but again, after a few laps of a regular size track, they'll overheat and get greasy. Not an issue for TT events but could limit your fun.
vincentjm
vincentjm
Switzerland
Vincent
'15 Mustang GT PP
I'll go with the RS4's then. What dimensions should I get? same as the OEM pirellis?
Was thinking of going with 265/35R19 front and 285/35R19 in the back, 10 wider than OEM and 35 sidewall instead of 40 (Stock PP wheels).
BmacIL
Enginerd
Naperville, IL
I would look at 275/35R19 on all four corners on 19x10s if you're doing dedicated track wheels. They'll fit on OEM pp wheels too.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I’ve tracked the RE71R a fair amount (CotA for example). Yes they’ll wear quickly when hot but they grip well enough. They’re only bad in the wet if its cold+wet (can’t come up to temp), or if standing water is a concern. For warm damp conditions they’re good.
see if you can get the RE71RS its more of a TT tire and may last longer with a little less raw grip, or the RS4. You can go as wide as 285/35R19 on the staggered PP wheels (but you might need a small 5mm spacer, I can’t remember). I’d run 275/35 or 275/40 too.
vincentjm
vincentjm
Switzerland
Vincent
'15 Mustang GT PP
I have 23mm spacers all around so fitment shouldn’t be an issue. I guess 265 front, 285 rear should be fine then?
shogun32
Northern VA
go 10" all around (zillion threads on that) or go 10/10.5 or even 11/11. I mean it IS for a specific use case so why not optimize instead of dicking around with 9/9.5.
NightmareMoon
If you go 285/285, thats what the autocrossers do (yes on 9/9.5” PP1 wheels), because then once midway through their life you can dismount the tires and cross rotate them to get a little more life. 285 bulges a but but they’ve proven just as fast as any narrower tire and the rotatability is a plus.
I burned through 4-5 sets of 285/35 RE71Rs on 9/9.5” wheels at autox and track days before moving up to 305/30R19s on 11” wheels.
Apex Wheels
Gold Sponsor
Bay Area
Mustang
If you're trying to get something that can work on the street and still be competent on track, the Hankook RS4 is probably the best option.
When the time comes for a dedicated setup, I would recommend our 18x11" ET52 wheels with spacers up front so you can rotate, wrapped in 295/30-18 or 315/30-18 Nankang AR-1 or 305/35-18 Nitto NT01.
Apex Wheels
Gold Sponsor
Bay Area
Mustang
You'd have to be the hulk to be able to stretch out 18" tires onto 19" wheels :shock:
Dang them typos haha. Edited above for clarity :cwl:
