Touch less car wash
#1ford
#1ford
Joe
2021 mustang gt premium convertble antimatter blue
Do touch less car washes cause damage? I was told that the soap is hard on the your paint! What do you think 🤔!
KingKona
Virginia
Shlomo
2019 GT
It's touchless.
I would guess there's some truth to that. But a heavy coating of wax or ceramic means no worries.
It also doesn't get your car very clean. Best to just do it properly if you can.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It's a mustang, touchless is just fine.
Depends on the chemicals they use. Not all are the same.
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec
As a rule, the soaps in the touch less car washes are very alkaline to help remove road film without contact. This is OK on occasion but over time it can degrade things, especially trims (ie rubber, plastic) and any coatings or sealants that are applied. Again, not a problem occasionally, much better than the spinning scratch o matic brushed units. I even use very alkaline soaps in my hand wash procedure occasionally for decontamination washes.
Torched10
Atlanta
Bob
My touch less is my 17year old grandson .once a month,
skinnyb
Knoxville TN
Alex
GJarrett
Bradenton, FL
Gerald
2017 EcoBoost Premium
I have the over-the-top stripes on my EcoBoost. When I first bought it new, I used touch less car washes in the mistaken idea that it would be easier on the finish. Touch less washes use much higher water pressure to help scrub off the dirt. That high pressure started stripping off bits of my vinyl striping and I had to replace it. I don't use touch less washes anymore, just old fashioned DIY in my driveway. If you have OEM vinyl stripes on yours, do NOT use a touch less car wash.
DFB5.0
Australia
Mustang GT Fastback
Came here to say the same.
When you increase or decrease from pH neutral on a cleaning product, you also increase the cleaning ability. That works for heavy alkaline or heavy acid leaning. Acidity targets mineral deposits, alkalinity targets dirt and oiler substances.
Most car washes places use alkalinity to get quicker/easier results. However, when the intention is for a "touchless" washing method, you are dealing with very high pH values to achieve that. For occasional use, you shouldn't have a problem with this. However, repeated regular use will dramatically shorten the life a wax or sealant, along with drying out and discoloring unpainted plastic and rubber trim. Most ceramic coatings will resist these high pH levels though.
In other words, cause and effect. Increased cleaning ability = a harsher cleaning chemical.
