Torsen only comes with PP.
TicTocTach
DFWTX
Clair
2018 EBPP
Not sure if this is helpful, but my '18 EBPP A10 has an iron diff, 3.55, and Torsen.
whatsup62
Jupiter
To be honest for what I use my car for and my future goals I would rather have a Trac-Loc vs the Torsen but would rather have a iron diff vs the aluminum. Maybe one day I can switch housings when I am making real power. Just sucks because that is going to be expensive and/or time consuming.
if its for straight lining the Torsen is stronger.
Furiosa GT
Furiosa GT
Edmond, OK
Shawn
2019 Mustang GT Premium
Then something has changed with it since the last GT500. Guys were blowing Torsens up at the dragstrip with Torsen equipped cars but GT500 equipped with the Trac-loc were in the 9's completely stock rear end. That's saying something considering the serious low end of the GT500 and driveline shock since all those cars are manual trans.
whatsup62
Jupiter
Yep..the Super 8.8 is different...torsen getting it done. With that said i havent heard much on any 2015+ center sections failing.
Furiosa GT
Furiosa GT
Edmond, OK
Shawn
whatsup62
Jupiter
Yeah...that wasnt the internals...that was the Aluminum housing. The autos (15-17 anyway) came with Aluminum housings and stick cars had the steel casing. The Aluminum ones wont handle high hp on a dragstrip launching hard.
Furiosa GT
Furiosa GT
Edmond, OK
Shawn
That was the main reason I wanted a iron housing in the first place cause I remembered the BMR car doing that. Of course it will be a while before I'm making that kind of power and especially those kind of 60fts.
millwerks
Algoa, TX
Clark
2018 Mustang GT Premium A10, Steeda K Brace, Strut brace, Differential mount bushings, IRS mount spacers and sleeves. CIA and programmer in box waiting for tune for weeks now...
You can get a loaded differential for under a grand and swapping them out only takes about 3 hours. As stated above if your just wanting to drag race torsen isnt your best option.
MRGTX
CT
2020 Mustang GT 6spd base
When are folks finding that the standard clutch pack style diff is letting them down?
Are they at a major disadvantage on the autocross course?
TeeLew
So Cal
Tim
When I bought my 2018 base model GT MT-82, it has an iron housing, and my sales slip said it had 3.55 gears and a "limited slip differential".
Is it a clutch pack type? I thought all limited slips on manuals with 3.55 were Torsens?
I bet that's a Trac - Loc diff.
TeeLew
So Cal
Tim
If built properly, they're probably OK. They just wear too fast when stock.
MRGTX
CT
That’s what I gathered but do people really get stuck needing a rebuild? what’s the typical interval for an enthusiastically driven car?
TeeLew
So Cal
Tim
What happens is the friction material wears off the plates and you lose preload. Once you get enough plate wear, the thing will lose enough locking ability that it's essentially an open. It doesn't take long.
I did see a guy that would remove *all* the friction material off the plates and then add in extra plates to achieve the same clutch pack stack height. Adding plates adds locking ability, so that's a positive. By removing the friction material off the plates, you end up running the plates steel-on-steel, which reduces the wear issue significantly. This is how every racing differential is built. The negative to this is that it is noisier in low speed corners and will tend to scrub a little bit if you're driving around a parking lot.
Elp_jc
None
I wasn't aware the diff is steel. I won't abuse my Bullitt, so that means the 3.73 Torsen should last until the end of days, right? :D How much heavier is a steel vs aluminum diff? But guess the diff is not where you want to save a few dozen pounds, no? And yes, will change the fluid early, to get all the assembly and break-in crap out of there. Thx.
