Top Speed for an Ecoboost
dspenc8888
Jax - FL
Dawn
2015 Mustang Oxford White EB Prem 50Anniv, 201A
^ That was my original thought, 3.15's on mine... But, now I don't know since some people say auto premiums, no PP are 3.31's.
Correct non PP premiums are 3.31 no cost or u can purchase as option 3.55 ...applies to auto or manual.
On base non PP models manual is 3.31 and auto is 3.15
PP has 3.55 or u can purchase 3.55 separately as stand alone option
stangs-R-me
Northeast Wisconsin
Doug
1969 GT & 2016 EB Mustangs
To answer the OP's question ...
Say a 2015 EB can actually get up to 5500 RPM (max HP) in OD 6th gear, these would be the theoretical speeds at 5500 RPM:
3.31 M/T w/ 235/55-17" ... 186 MPH
3.31 M/T w/ 235/50-18" ... 187 MPH
3.55 M/T w/ 255/40-19" ... 175 MPH
3.15 A/T w/ 235/55-17" ... 198 MPH
3.15 A/T w/ 235/55-18" ... 199 MPH
3.55 A/T w/ 255/40-19" ... 175 MPH
Doug
stangs-R-me
Northeast Wisconsin
Doug
Per both the Order Guide and Ford B&P:
* The 3.55 stand alone option (455) is not available on EB, only V6 & GT ... the only way to get 3.55 w/ EB is w/ PP option.
* 3.31 is std. on all EB M/T (no 3.15 option)
* 3.15 is std. on all EB A/T
3.31 n/c opt. on EB A/T only shown on Ford B&P ... also I could add it to either a Premium or Base EB. Honestly think this is an ERROR on Ford's site as I can't find this fact anywhere else and I find it extremely hard to believe Ford would offer an optional axle ratio at NO COST.
Show us proof of a "Window Sticker" or other official Ford documentation of a car with A/T & 3.31 gears !!
Doug
neodark
Left 4cyl @home
Jorge
2019 GT PP2
So back to not really knowing what's on mine. if 3.15s I may think of an upgrade to 3.55s down the line. with 3.31s not so much.
RubyRacer
PA
22 Mustang GT 6M
3.55 is perfect... except you can't get to 60 without shifting to third! So annoying.
I think you can literally get to 58mph when you bounce off redline in second. It's a very frustrating thing.
I would just raise the rev limiter, which I did with my SCT X4, but these cars die so much above 5500rpm that I honestly get the same 0-60s whether I push second gear to redline or shift to third so I can use the meat of the curve.
So, I guess my biggest gripe isn't necessarily the gearing, but rather the lack of power up top to make a small rev limit bump work.
dspenc8888
Jax - FL
Dawn
Similar power/weight numbers so forgive me if the info isn't helpful, but on a closed course (i'm not kidding about the closed part, no "Mexico" stuff) i've been able to get a '14 V6 to bury the speedo past 160mph. 3.73's, a tune, and BFG comp-2' with a speed rating of 168mph being the mods.
Wow, impressive:headbang:
dspenc8888
Jax - FL
Dawn
Doug
I have ecoboost premium non PP and Ford service dept validated I have 3.31 because that's what is on all premiums unless u opt for PP or 3.55 option, at least that's what I was told.
Would be nice to know for sure though because it makes more sense to upgrade if at 3.15. I won't upgrade if already at 3.31 to costly.
neodark
Left 4cyl @home
Jorge
2019 GT PP2
Was that V6 Mustang @ 160 with the stock driveshaft/tires?
[ame]
stangs-R-me
Northeast Wisconsin
Doug
There you have it ... "Ford Service Dept" validated it ... must be fact then.
Read through the Order Guide, or crawl under your car and look for a tag on your differential.
People on this forum typically know a lot more than ANYONE at you average dealer about these cars.
Another way to check would be to look at your RPM's at speed.
If you've got 3.31's you'll be turning about 2000 @ 69 MPH in 6th gear
If you've got 3.15's you'll be turning about 2000 @ 72 MPH in 6th gear
Doug
neodark
Left 4cyl @home
Jorge
2019 GT PP2
If you've got 3.31's you'll be turning about 2000 @ 68 MPH
If you've got 3.15's you'll be turning about 2000 @ 64 MPH
Doug
Awesome, thanks :thumbsup:
stevnoof
new jersey
2016 mustang gt base manual 3.31
130 and steadily rising according to my gps but ford says it only does 121.
McCarthy
Canada
2014 Mustang
Yes i'm aware of the driveshaft failing. It was a stock driveshaft, but had proper W rated (168mph) BFG Sport comp-2 tires, 3.73 gears and a tune to remove speed limiter.
I lost the video but I still have a still of the speedo from it. Again, I would like to re-iterate this was done LEGALLY on a closed course. I'm all for having fun on public roads, but speeds like that are for tracks/runways/closed courses ONLY.
Papaya
Stony Plain, Alberta
Holger
F150 2.7 EcoBoost
:D You never drove on the Autobahn? That was normal speed (220 kph) for me going to work to Frankfurt / Germany..... :headbang::thumbsup:
wildsailor
This Club for me?
SE Michigan
2015 Ecoboost
For the Ecoboost (base and premium):
3.31 axle comes with the manual trans (non-PP).
3.15 axle comes with the automatic trans (non-PP)
3.55 only comes with the Performance Package and is not available as a stand alone option like it is on the GT or V6.
Alloy
S550 EB
So it looks like I can just buy the 3.31's since I have a base auto eco. But when I looked at the install for this, there are quite a few specialty tools they list to use. What can i expect to pay to have this installed? And would the gains be worth it versus cost/install?
