Top speed 2015 GT no speed limiter?
Glenn G
Kaiserslautern, Germany
Glenn
15 DIB 6MT base Ecoboost
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2025 Mustang DH HP
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
This would be with the 3.73 gears I am assuming since it's a Euro spec?
I think all euro cars are 3.55 on M6 and A6.
My UK GT PP is an M6 3.55 traction lok diff as standard.
wireeater
Virginia
wheelwell.com
Rich
Oh OK. I knew you guys got the PP standard, but wasn't sure on the gears. I think 3.73s top out around 150ish. I know someone doing 1/2 mile runs was topping out around 150ish-160ish.
Grintch
Hunstville
2015 GT PP
3.73s put you at 150 @7000 in 5th.
3.31s put you at 170 in 5th (6th calculates as a too tall, never gonna happen 261).
I would expect peak power to be between 6500-7000 unless you are running a GT350 or CJ manifold, so I wouldn't expect a higher rev limiter to help much for top speed, were you need peak power.
So 170 is my bet.
7500 rpm, if you could pull it in 5th, puts you at 180.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Put bigger tires in the back.
I think with 3.73 gearing, there should be some decent acceleration in 6th gear right?
3.31 is not possible unless you FI.
Grintch
Hunstville
2015 GT PP
3.31 is not possible?
3.31's in 5th have 37% more torque multiplication than a 3.73 in 6th. So a 3.31 will leave a 3.73 at 150+. If you had 600+ HP, the 3.73 would have an advantage at 180+ (assuming MT82 6 speeds).
RoadCone
Ohio
2016 Competition Orange PP
This would be interesting considering I have a 3.73 and MT82....:D
Grimace427
NoVA
2011 Mustang 5.0
Putting bigger rear tires is a good idea for some extra top end.
6th gear will effectively end all acceleration at higher speeds. I ran the Texas Mile and tried shifting into 6th at 150mph and it felt like hitting a brick wall. Running it out in 5th is the only way to hit top speed unless you are making massive power from forced induction.
3.31 gears are the ones to have for top speed runs on an N/A Coyote.
ahl395
Allan
Does anybody know what the limit is of the OEM driveshaft?
I remember a few years ago V6s removing the limiter and they were known to fail over that speed. Curious if it's the same for us at 164.
I'd like to see what I could do with 600-700whp and a 3.15 A6. Don't think I ever will get the chance though. :headbonk:
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
I don't think there is a limit on the GT drive shaft. Lot of 800HP superchagged GTs running the stock shaft around here.
Grintch
Hunstville
2015 GT PP
Yes, but not much tire selection in 28"+ diameter tires. Most of us are running significantly shorter than stock tires because even the stock diameter has poor tire selection. Plus changing tire size (when you can) usually has less impact than changing the final drive/gearing.
