Top Speed 1/2 Mile Event
Houston Kid
Houston, TX
That's hauling some ass. What do you think it could hit in a 1 mile run?
SlowArrow
NorCal
2016 GT350
Excellent! Been watching this build, it just looks awesome. I not sure I'll ever be able to convince myself to add forced induction.....that said I really like your setup.
What did you change in pushing above 170 - did you add more boost? A tire change would likely help as well. Were there any stock GT350's running, and if so what did they turn?
PencilGeek
Northern California
Robert
2017 GT350R HR278, 2008 BMW M3
6th gear would be a problem for standing mile event. You'd either need to change 6th gear, or change the final drive to be much taller (numerically smaller) to allow the car to hit it's max speed in 5th gear instead of 6th. Without a change like this, the standing mile trap speed wouldn't be a whole lot more than what he's got here. I'll see if I can find his dyno chart and simulate it and give you an exact answer.
TonyJ5150
TonyJ5150
Indianapolis, IN
2016 Shelby GT350
Will be doing a gear change this fall/winter..
As far as what we did to go from 165 to 173....turned out the traction control was clicking in and pulling timing and ignition just before the traps...felt like a rev limiter...we pulled the correct fuse and that was it....was a handful for sure.
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
Congrats, I live near the Texas Mile event site and watch for Van Collier's runs each year. I just installed BMR camber bolt with the 4 pt. cb006 front subframe brace, aligned to 1.5 neg camber for running thru the twisty's. I too, have a need for speed.
TonyJ5150
TonyJ5150
Indianapolis, IN
2016 Shelby GT350
john@fatfab
Indianapolis
Shelby Omni
Stock block and heads?
Yes. The only items we changed in the engine were the oil pump gears and the timing chain gear. This is something we do to all 5.0/5.2s when going forced induction rather it be supercharged or turbocharged. I know some will argue that the engine is no longer "stock" with these changes but I that is really splitting hairs at that point. I think that once you are changing anything from the rotating assembly ie pistons, rods and crankshaft then it is considered a built engine....thats just my opinion though.
Epiphany
Global
I like to disassemble things.
Looks like the hood could use some "thickening" to the sheetmetal beneath the Aerocatch latches. Almost looks like depressions surrounding them from holding down the fort at speed.
john@fatfab
Indianapolis
Shelby Omni
That depression is due to it being two layers of metal. It was like that prior to making the runs. When installing them we were aware of this so we left the bolts as loose as we could, but the hood is really thin aluminum so it deforms really easily. We are currently making some little spacers to fill in the gap so we can tighten them down without it pulling on the top layer like it is in the pictures. We just ran out of time as they were being installed Friday night just prior to loading it in the trailer to head to the event. I will post some pictures of it after we get the spacers made and installed.
EF300
The Swamp, Central FL
2017 GT350, 2020 GT500 CFTP
This car is just amazing. Could I ask for fat house and your comments on your choice of turbos over supercharger. I'm sure you debated the merits of both. I really would like to do a twin-turbo setup although it does seem to cost substantially more than a supercharged setup.
