Top end feels flat
bms44
Ipswich
Ben
Mustang Bullitt
Afternoon all, I posted in the UK section but wanted to ask the Bullitt section as well. I recently purchased a 2020 Mustang Bullitt and I’m thrilled with it however I took it out today and it felt unusually flat at the top end, 5500rpm+
Like it would build power and torque normally until 5500 then just plateau instead of building.
just wondered if anyone could give some advice before taking it to a garage.
cheers.
robvas
MI
2011 GT
Do you have any way to datalog it with a tuning or obd2 device? Misfire code? Stuttering because of a bad coil/plug? Bad fuel?
Has anything been done to the car at all recently?
bms44
Ipswich
Ben
Mustang Bullitt
I’ve no way of data logging. Its recently had a H pipe fitted but that’s it. Ill test it tomorrow and if it persists ill ring the specialist garage.
17MagMetal
San Francisco
Michael
17 Mustang GT, 07 Ford Taurus SE, 95 F250 Xlt
Any mods? On road these cars get hilariously sketchy past 4500-5500. Definitely not normal.
bms44
Ipswich
Ben
Mustang Bullitt
Just a H pipe, I’m thinking potentially it’s just some poor fuel, the issues started right after filling.
Topdown
Sydney West
Os
5.0 Gt Convertible 2021 (TBA)
Sounds a lot like mine once i got an H pipe it seemed to lose some HP. To be honest i find the Bullitt (19) not that quick. Ive got 21GT convertible as well and that really pulls. The Bullitt replaces a Stinger GT (2) and that was way quicker as well. I vary the fuel so its not that, but is definely a sluggish car ☹
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
What octane fuel did you add?
Nightmonkey
Germany
Jens
2020 Bullitt
RHD, right?
Maybe the RHD exhaust manifolds are the reason?
Not sure, if RHD got a different tune from factory because of the RHD modified manifolds?
raptor17GT
Scotland
Mustang GT Manual 2017 - now sold ☹
OP says it felt unusually flat after filling up so RHD / LHD in this instance makes no difference. Any update OP ?
WD Pro
United Kingdom
Lime GT
Yes there is defo a very clear difference between bottom end (below 4.5k) and top end (above 4.5k) on a RHD gen3.
If the OP regularly uses the top end, it would be blatantly obvious if something was amiss / different than normal :like:
As a fist step (steps), I would fill (from empty) the tank with quality fuel, do a KAM reset, then take it for a little test drive.
WD :like:
bms44
Ipswich
Ben
Mustang Bullitt
Sorry for the slow update, I was advised to refill the tank with V power and drive through that tank. I don’t want to jinx it but it actually seems to have worked, top end feels as it used to. Not sure if that means it was just a bad fill up or something else but as of yesterday it felt normal which is great as the top end is one of the reasons I love it.
