Tire Width Recommendation
Prodigal
OKC
2021 Mach 1
I have a set of 10.5/11.5 x20” wheels about to arrive. Looking for tire size (width) recommendations. Car is non hp Mach 1 but will have .75” drop Steeda Dual Rate springs and camber plates. and factory Mach 1 wheel lip trim front and rear. Was leaning towards 295 / 315 but I see a lot for folks running 305 up front. Thoughts on 305 / 325 front / rear? Car is not tracked. Looking for flush fit or miniscule poke if unavoidable.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Would need to know additional details to advise on what would or would not fit (specifically the front).
EFI
Masshole central
5.Br0
You're kinda splitting hairs there, you won't notice that much difference between 10mm worth of tire.
For track driving I prefer to go on the narrower side for more direct feel. For the street I prefer to go a bit wider for the meatier look.
Coastal-Mach
Wilmington, NC
Anthony
2023 BMW M440i, 2026 GMC Denali, 2021 Jeep JK
I don't think you will have any issues running the 305 fronts, the HP come with them from the factory, so going 20's should be good, if you stay with a 305/30 VS 305/35. The 325 will fit perfect. Good luck, and post up the new wheels when they arrive.
