Timbostang
I just wish bama would hurry up and get me my tune!!!! My focus, xterra, and 98 gt all have better throttle response than this car!!!!
dcrypter said there were no modes on the base care. Pretty sure, 'Sport' lights up when you do this, so it is in Sports' mode at that point. Never said it was a 'driving' mode - however you wish to define that.That's not a driving mode, that only applies to the traction control, not the throttle response.
To me it feels like normal mode only scales from 0-80% throttle with a super nanny, sport being 0-100% with a conservative nanny, and track 0-100% with nearly no nanny.What is the response limit of the throttle engagement (gas pedal) with sport and track mode?
I ve never tried to rev up all the way to the red line with different modes on neutral, i shall try and see. My guess is the throttle won't reponse after the gas pedal is like half way down in track mode, which is hitting the rev limiter! The rpm should be linear with how much you press that pedal. Otherwise it feels like you are playing a racing video game with one button acceleration.
I might be old school here. Oh well!
This is what it does, but a driving mode changes the steering, throttle response, and traction control. It might actually do some other stuff, but I have a feeling that outside the throttle, the base is able to do everything the premium is. I don't think you can customize the suspension on the go, so that's not a worry. I can't think of what else the driving modes would change.This was my understanding. Less nanny so you can spin a little more before it kicks in but still not the driving modes.
The driving modes definitely change when the PCM cuts fuel as well. You can hit 7k~ rpm with track mode (and the Roush blower makes power all the way up to like 7.5-8k too if only my tune would let me)This is what it does, but a driving mode changes the steering, throttle response, and traction control. It might actually do some other stuff, but I have a feeling that outside the throttle, the base is able to do everything the premium is. I don't think you can customize the suspension on the go, so that's not a worry. I can't think of what else the driving modes would change.
Interesting. First I've heard of this.The driving modes definitely change when the PCM cuts fuel as well. You can hit 7k~ rpm with track mode (and the Roush blower makes power all the way up to like 7.5-8k too if only my tune would let me)
Premiums also flash red when you get to redline telling you to shift. It gives you about a second of redline before it cuts fuel instead of the instant cut that normal mode does.Interesting. First I've heard of this.
I knew about the flashing red at redline. Does sport+ give you the extra second as well?Premiums also flash red when you get to redline telling you to shift. It gives you about a second of redline before it cuts fuel instead of the instant cut that normal mode does.
I'm not 100% sure but I believe sport and track both give you a little leeway at redline. I usually skip sport if I want to have a bit of fun though.I knew about the flashing red at redline. Does sport+ give you the extra second as well?
Same here, i always hit the fuel cut around 6850 rpm in normal mode, i wonder if the track mode really allows you to go higher than that!Interesting. First I've heard of this.
Ah, so it changes throttle response, the fuel mapping, steering, and traction control?The driving modes definitely change when the PCM cuts fuel as well. You can hit 7k~ rpm with track mode (and the Roush blower makes power all the way up to like 7.5-8k too if only my tune would let me)
Steering feel is only modified by the settings on the driver display(probably not the right name but the display between your gauges) AFAIK. You can be in track mode and still have it on comfort, sport, or normal steering feel I don't think it changes that.Ah, so it changes throttle response, the fuel mapping, steering, and traction control?
