Thoughts in steeda intake?
BrantMcE
Tampa, FL
2015 Mustang GT Premium Magnetic w/ Dark Saddle In
HMMM seems like most guys are getting that now, I might have to ask for the restrictor less tune :-)
I was monitoring airflow and temps today (with restrictor) and at IDLE I'm at 20 parts air at WOT I range between 11 and 13 and at normal cruise (6th gear, 60 MPH) I am steady between 14-15 parts. Air temps range base on the time of day and sun factor. It more the sun beats on the hood the hoter the engine bay is. I was into the low 80's this morning (ambient temp was 76) and as high as 103 at a light. This is using the gauges in the vehicle. I wonder just how well the top of the air box seals to the hood.
I'm also curious as to the seal against the hood, however I'm not sure what kind of temps the stock intake had at a stop in traffic. Anyone with the stock intake care to chime in on their inlet temp at a stop after driving around?
IvanCRF
El Paso, Texas
5.On'ry
On a 5 hour road-trip, I had a temperature range of 3-4 degrees F with my stock set-up regarding inlet vs ambient temperature.
Tubalkayne
First Time Mustang Owner
Largo, FL
Brian
2015 Mustang GT, Steeda PP, Competition Orange,
Ok let me specify I need stock temps in Florida not Maine!
Mustangtk
South Florida
2015 Mustang GT PP Ingot Silver
I've been averaging about 84 F with sock about to install my steeda CAI this weekend
silver.gt
2015 silver gt
One quick thought steeda, I think you forgot to put a drain hole on the bottom of the intake box for when water get in, JLT has one, my ford racing cai on my bullitt had 2 if I remember correctly. I just got my intake today didn't have time to put it on but for sure tomorrow it's going on, but I think I'm going to drill a hole or 2 just in case.
Phlyguy
International SAR Pilot
Greensburg, PA
Marc
2015 Ruby Red Mustang GT with Recaro Seats
Think that's an excellent idea...plan on modifying my box as soon as I get back
SSLByron
Media Hack
Annapolis, MD
www.leftlanenews.com
Byron
'15 Guard GT PP
I noticed the lack of drains too, but then I was thinking about it and isn't the cold air pipe downhill from the airbox? Any accumulated water would just drain out that way.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Wait, we have to modify the box ourselves?
BrantMcE
Tampa, FL
So after driving around in the hot Florida sun, I got home and decided to pop my hood and check to make sure I installed everything correctly as I still think my air inlet temps seem awfully high given everyone else is running less than 10° above ambient. Everything seems to be installed correctly however I did notice that while the space within the airbox seems considerably cooler than elsewhere in the engine bay, the aluminum connection seemed extremely hot. Could this possibly be the reason why my temps at a standstill are climbing so high?
Tubalkayne
Largo, FL
Brian
Could be, I'm sure the temps are comming from the MAF vice the air box.
David@Steeda
United States
www.steeda.com
David
Bolt-on, slammed S197
It's normal for IAT to climb at a standstill with both the production intake and an aftermarket CAI.
If you checked it with the factory box, the same scenario would occur.
Trackaholic
2003 350Z, 2016 GT350, 2018 Pacifica Hybrid
At idle you aren't flowing much air, so it will pick up heat as it goes through the intake piping. Once you are on throttle, the air velocity will increase to a point where it won't have time to pick up much heat, and will be influenced mostly by the temp of the incoming air.
So, once you get on the gas the temp should drop.
At this point I don't think the temperature rise at idle is anything to worry about.
-T
BrantMcE
Tampa, FL
Thanks for the responses guys, I wasn't sure as I never monitored temps with the stock intake, but figured better safe than sorry. One other question though, the whistle when about 1/4 throttle is normal right? I find it only occurs when I'm on the throttle a certain amount, any less or any more and it disappears.
Tubalkayne
Largo, FL
Brian
Folks I would look into putting a couple of holes in the bottom of your intake. I washed her this morning and when I opened the hood I had some standing water in there. I put 2 holes I. The areas where the standing water was to drain it out.
BeauxXL1200
Austin, Texas
Ralph
2015 Mustang GT/PP Ruby Red
That's interesting Brian. I suppose if water is collecting, popping a couple of holes to let it drain is a good idea. Kinda surprised it didn't come with drain holes.
I'm very much considering the Steeda CAI. Right now, I'm running Ford Racing's touring cat backs and a Bama 93 octane tune. I would hope that adding the CAI and updating my tune to match would add at least a little HP and torgue.
Other than the standing water issue, are you pleased with Steeda's CAI?
