Dave2013M3
- Aug 22, 2014
- El Segundo,Ca
- 2020 Ford Mustang GT Base PP1 6MT Rapid Red
Guess I’m a little confused. Did they change the ratios on the Getrag that much between 2015 and now? Mine is a 2015 PP1 and I have the FRPP2. I noticed a good difference in the power, but have always been disappointed in the transmission gearing as 1st always feel like a granny gear. Hard to keep traction and then it’s already time to shift to second.
Now I understand the references to D3 and D4. Thank you, didn’t know!Huge difference, the new gearing in the D4 Getrag basically neutered alot of the power advantage from a the Coyote 2 to Coyote 3.
Well, not really. The post on page 1 where refers to D4 that is for direct 4th, the 1:1 gear ratio in the MT82D4. D3 is incorrect as there is no direct 3rd version of the MT82. He meant D5 to refer to the direct 5th 1:1 gear ratio of the MT82.Now I understand the references to D3 and D4. Thank you, didn’t know!
Not sure why they said you need a computer reflash. After changing mine to 4.09's, no computer work needed and the car reads the correct mph. But if $1100 includes all the parts that's probably a decent price. There's a lot of labor to remove the differential to be able to get to the gears. The guy who did mine is a Ford service writer and said most of the labor cost is the diff removal and reinstallation.Dealer quoted me $1100 which included 2hours for the computer re-flash (which may or may not be needed). Installing ring and pinion properly takes some finesse and effort but that seemed high to me. How much have you guys paid for this job?
Thank you! Now I know the difference. I realize this bucks the trend, but I wish I had the new ratios.Well, not really. The post on page 1 where refers to D4 that is for direct 4th, the 1:1 gear ratio in the MT82D4. D3 is incorrect as there is no direct 3rd version of the MT82. He meant D5 to refer to the direct 5th 1:1 gear ratio of the MT82.
I have to ask why. With the MT82D4 the gears you want to be closer ratios, 1st through 4th, are spread wider than the MT82 and the double overdrive gears are close ratio, which is pretty pointless. Out of the MT82, the Calimer/GGforce level 3 rebuilt MT82, the MT82D4, and the Tremec TR3160, the TR3160 has the closest and most usable ratios.Thank you! Now I know the difference. I realize this bucks the trend, but I wish I had the new ratios.
You don't - my '18 with 3.73 feels slower than '15 with 3.55 - and I jumped from one directly into the other so had a direct comparison. at least 1st and 2nd are too tall. Which is why OP in this thread wants 4.01.Thank you! Now I know the difference. I realize this bucks the trend, but I wish I had the new ratios.
This is great to hear.Not sure why they said you need a computer reflash. After changing mine to 4.09's, no computer work needed and the car reads the correct mph. But if $1100 includes all the parts that's probably a decent price. There's a lot of labor to remove the differential to be able to get to the gears. The guy who did mine is a Ford service writer and said most of the labor cost is the diff removal and reinstallation.
To make what work correctly? The speedo automatically adjusts without any programming.You will need to change the ratio in the pcm to make it work correctly. That can be done with forscan. It's a simple procedure with a laptop and a forscan approved cable.
