Thermostat question
Kashawy
Gold Coast, Australia
Khaled
2015 CO Mustang GT, 2012 Black Golf GTi
There are several threads about how to do it, very easy but could be messy depending how you do it.
One method is to take off the pan under the front of the car, a whole lot of clips and bolts, then you drain the radiator from the petcock on the right side of the radiator. I did it like this once and it was draining fine until I opened the cap to the overflow bottle then it came streaming out so fast it missed my bucket and I lost about a QT of fluid.
The next time I just used a hose clamp (looks like vise grips that have flat teeth then squeeze the hose coming from the bottom of the radiator, I used an extra large ziplock bag that I got from Ace Hardware to catch any fluid coming out of the connection where the TStat is located. You loosen the two 8mm bolts on the hosing just below and to the right of the throttle body that has the bottom hose connected to it. The thermostat is inside of that hosing pull it out along with the gasket. If you have the 170 you wont need the gasket.
Hope that helps.
Easiest way to install the theromstat is to use a hose clamp. I didn't have to remove the pan or lift my car. Took 30 mins and barely lost any fluid.
I will post pics later.
That doesn't sound easy. I thought I just have to remove the old one and replace it with the new one, what fluid are you talking about?
I'm probably not going to do the installation myself, but I'd like to know just in case the installer has no idea.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
I'll post some pics tonight. The hardest thing is the back 8mm bolt if you have big hands. I'll post a pic of the clamp too. It was only $8 on amazon.
sandeale
North Carolina
2015 GT Premium PP
I'm running an awesome duralast (autozone) 160 degree thermostat that cost me like 20 bucks and have no issues whatsoever cylinder head temps creep up to 190 on a full rpm hit but remain around 170 to 180 ish while cruising (depends on ambient).
The key is to properly bleed the system.
ifly680g
Hebron, IN
Mark
2015 Mustang GT PP
We are talking about the Even Flo 160 it sounds like the Duralast is working great. When I had the Even Flo 160 in I had CHT as high as 214 and never below 190 even driving slow with 30 degree outside temps..
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
It's not so much about brand it's design. It seems even Duralast knows how to build a T stat. The Reische looks identical to OEM the EvenFlo does not
sandeale
North Carolina
2015 GT Premium PP
Yeah that sounds as if the thermostat wasnt "even-flow"ing...seriously sounds as though the opening temp was off because thise are stockish temps, based on the components used in the reische 170 im sure its a better piece
Jmeo
You said member ;)
Massachusetts
Jaime
The Evenflo opens at 160° like designed. I believe it's design is the flaw. It has 4 holes drilled in one end and OEM or Reische does not. I think this is causing some kind of bleed by or something.
Who the hell knows, it works, just not as good
zaquhree
Orlando
2015 S550 GT
Lethal can definitely help you with your thermostat needs, I know they pointed me in the right direction.
Socalmustang
California
2015 Ford Mustang GT Premium w/PP Race Red
I bought my Ngauge with the 160 thermostat, it was the only one they offered and did not do enough research.
Unopened and new...anybody want for free?
Wally-Bob
Pompano Beach Florida
Wally-Bob
2015 GT Prem PP 50AP
I was told that this thermostat change only is intended for and only benefits boosted engines, not for use on naturally aspirated. Any truth to this claim?
Mikeg4572
Scottsdale, Arizona
2015 Magnetic GTPP
http://www.mustang6g.com/forums/showthread.php?t=37575&page=17
^^^ The prove that the 160 isn't as good as the Reische 170 is in this thread. Try searching before running your mouth.
I'm not running my mouth, but to say that the evenflow doesn't work as well because a few people reported issues is hardly enough evidence to say a Reische is better. I watched the previous threads on this, no search needed. If the 170 works for you, then great. My cylinder temps are significantly coole and right where I want them to be. I wouldn't want them any cooler.
Kashawy
Khaled
Install pics.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Thanks for the pictures. I just hope my installer did this before so doesn't ruin it.
BluByeU
M6G SoCal Cruisers
SoCal (Temecula)
Rob HT
2015 Premium GTPP Recaros & Shaker 401a
Regretfully I went with the Even Flo 160 as well, but will be switching to the Reische 170 before Spring. Not impressed with the 160 as far as it lowering CHT.
Mikeg4572
Scottsdale, Arizona
2015 Magnetic GTPP
I must be one of the lucky ones. My 160 works perfectly
