The Voodoo That They Do: Building the GT350’s Engine
coupe3w
MA
67 Mustang FB, 2021 Mach 1, HP, Shadow Black
One guy has an NHRA hat on. Cool.
Texican1911
Ford Certified Sales Guy
www.facebook.com
2018 GT 401a Lightning Blue with Midnight Blue 20" wheels Safe & Smart, Active Exhaust, Shaker
101charley
Franklin TN
Charley
2015 GT Magnetic, 400A, 6AT, 3.55, MBRP Street
I see no phoniness in the photos. Maybe these guys do care - and maybe they really like their jobs, take pride in their work and have a positive attitude - unlike some of the people who post here. :tsk:
And unlike the people I work with.
I am sure these guys care a lot.
Genxer
2015 Mustang GT / Perf pack / DIB
The article mentioned sharing basic architecture with the Coyote. Is there anything actually shared between the two engines, or are they just "like" designs? (with the obvious exception of the FPC)
5.0 435
North Atlanta.
.07 Shelby SGT #0016 ...18 GT PP1 manual
Cool pictures for sure. How many do they build a week ?
Grimace427
NoVA
2011 Mustang 5.0
The entire Voodoo engine is based off a Coyote. Put them side to side and you would not easily be able to tell the difference.
Schu
Las Vegas, NV
S550GTPP
would the V crank fit in a C block?
and extra .2 of displacement, it's either a bore differential or a deck height difference.
Hack
Minneapolis
Mustang, Camaro
mostly bore - thanks to the spray bore liners. IIRC there might be a little stroke difference as well.
JonnyMustang
Mustang Enthusiast
NETSEO
2013 Ford Flex EB
Are these the same guys that will be building the GT (supercar, not Mustang) motor?
chief135smitty
Charleston, SC
'16 GT350 w/track pack
I wonder how much the service will be when it comes time to change the timing chain? I can't recall exactly, but the book gave two time ranges for change. 1 for regular driving and a sooner date if you track the car.
Grimace427
NoVA
2011 Mustang 5.0
Does the 6G Coyote have the same bottom end as the Voodoo?
The bottom end includes the crank, rods, and pistons. None of those are shared.
I'm sure the crank would physically fit, but there was a lot of work getting the FPC to run smoothly so I don't expect you could just swap them.
The extra displacement came from the spray bore going from 92.2mm to 94mm.
Why would you need to replace the timing chain? It's not a timing belt. Unless the chain gets stretched from damage or defect it should last the life of the car.
chief135smitty
Charleston, SC
This statement is straight out of the owners supplement.
Timing Chain
If you use your vehicle extensively at a race
track or at high rpm, it is possible to exceed
the service life of the engine timing chain.
A wrench indicator light will illuminate
when it is time for you to replace your
chain. See an authorized dealer
olaosunt
Indiana
Any one know if the oil pump has billet gears?
I scored a GT350 oil pan /oil pump and was planning to use it for a short block build if it has the gears.
The pan is plastic ,lighter than coyote one and has a pick up tube for the oil pump .
Cascadia_302
PNW
2015 RubyRed GT M6 Premium
I should have been more specific with my question but was wondering about the four bolt mains and whether it's a cross bolt design.
