Dallas J
- Sep 18, 2014
- Oregon
- Website
- www.ssb-designs.com
- Dallas
- 2020 Mustang, 2006 Evo, 2019 F150
Hey all, working on some things and needed to really get an idea of the changes through S550 iterations. I'll post up what I'm finding so far, but feel free to help with data and double checking.
Why collate the data? I come from (and still a big member of) the Evo world, we share everything we know to build the community. Seems there's a bit of marketing driven "data" that's not really accurate. Id rather have a discussion to figure it out than play poker and hide my cards.
We know the upright has several versions, here's the count of what I've been able to find. Either visually or claimed online.
Well, I have a 2020 302a w/o magneride and bought used Mach1 bearings and scanned both. Heres the two lined up at the wheel mount face and aligned to strut angle.
As far as geometry changes go, within the noise they are the same. There is no roll center, bump steer, virtual pivot, or other changes related to the lower mount points. Its the same.
Beside the obvious wheel bearing and associated ABS sensor change, the strut mount offset seems to be the only "real" change here. There's an additional ~7.5mm clearance at the lower mount hole and 1degree additional camber. This of course gives that extra 7.5mm to inner wheel clearance likely to help with their 305/10.5 combo.
This is also a crosspost from the "other'" mustang forum. But this place seems to have a larger audience. If nothing else, maybe more people will call me an idiot here or refute any info posted ;)
If someone has a GT350 upright sitting around, Id be will to pay to ship it here, scan, and send back. Would be great to see any differences used on the other cars.
- Pre-2022 Non-magneride
- Press on bearing
- Magneride
- Bolt on bearing
- Solid back
- JR3C-3K170-a (or 171 for other side)
- Mach1
- Bolt on bearing
- hole through center
- NR3C-3K170-AA (171 for other side) stamped on body from parts ordered, and pictures from ford. PN at Ford Parts is NR3Z-3K185-A
- Seems to also be on 2022+ GTs.
- GT350/500 variants
- Radial Mount
- Unknown geometry differences.
