Talked to Fore about E85/pump maintenance recommendations,thoughts?
Unas2k5
Detroit
Samer
I emailed Fore innovations about E85 maintenance recommendations. I will attach the email. They also sent me a PDF file on how to maintain the vehicle for 85.
I also found a video on YouTube of Palm Beach Dyno and their 85 maintenance issues they ran into.
This is the video :
HKusp
Hampton, Md.
Jason
Thanks for sharing that info from Fore. Good thing I daily my car and my pumps are relatively small (Ti274's) so they don't generate as much heat as some of those huge pumps.
Unas2k5
Unas2k5
Detroit
Samer
No problem! Did you see the sludge he found on his filter and injectors? What a nightmare.
HKusp
Hampton, Md.
Jason
Yeah, that makes me nervous. I am currently running a stainless filter. I am going to need to look into one of those micro-glass filters.
jpjr501
Boca Raton, FL
Joe
2020 Mustang GT - Procharged
I got to drive my car more. PBD built my car and told me straight up, drive the car and I haven't been. I also have a Fore Innovations fuel system for my Procharger.
sms2022
Detroit
SS
2022 Mustang GT PP1 premium
1/2 tank a week is a lot of gas. Maybe I’ll start running just a quarter tank when I want to run E so I can top off with 93 if the car is going to sit.
sms2022
Detroit
SS
If you know, is there Any reason to run a supplemental filter with the factory fuel setup and E85?
HKusp
Hampton, Md.
Jason
I do not know how good the factory fuel filter is, but I would assume it's pretty good to the point that they can warranty these engines despite the vastly different quality of fuel throughout the country. So I would think you are pretty well covered.
Unas2k5
Unas2k5
Detroit
Samer
He also said this : You guys have any questions I should ask him?
Unas2k5
Unas2k5
Detroit
Samer
I think I can make 700WHP safely with my setup on 93 and my low compression motor. I’m making the switch. If I have a race then I’ll switch to E85 but what I’m not gonna do is let it sit in there and destroy my car
SheepDog
Colorado
Dax
I saw that same video and immediately ordered a Radium Microglass filter (6 micron) . I Had been running a Fore Stainless steel filter. 4,000 miles of nothing but E70 (we don't get E85 here). When I removed it, it was spotless. I think that sludge and buildup you seen in his video must either be that he was getting bad fuel, or that water was making its way into his tank. Ethanol is hygroscopic and so if you live in an area with high humidity, it's more important to make sure there is fresh fuel cycling through the system.
As far as fuel temp goes, After an hour of driving, I will see around 100 degree temps. My ethanol sensor is on the return side of my system, right after the drivers side rail and before the pressure regulator. Im sure over time that the fuel in the tank would eventually reach that temperature, but this thing goes through it so fast, that even a couple hours of spirited driving and Im filling the tank back up with cold fuel anyway
CrackedHorn
Kansas
09 Mustang GT/CS; 15 Mustang GT
So, how does a person store an E85 car over winter then?
SheepDog
Colorado
Dax
By draining the E out of it, or burning it up and then filling the tank with gasoline (and flashing the appropriate gasoline tune obviously) prior to storage.
HKusp
Hampton, Md.
Jason
I know a decent amount of guys who store it over the winter with E in it, and fire right up when they take it out in the spring and report no issues. That being said, I would probably do as Sheepdog said and run it down very low, flash the appropriate tune at the gas station as I filled up with 93, add some Stabil, drive it home and call it good. Mine won't sit though. I put 200+ miles a week on mine every week unless there is snow on the ground.
Unas2k5
Unas2k5
Detroit
Samer
So thing under my car has the fuel filter? I’m not even sure wether I have the micro glass or the stainless steel
