Sync 3 Upgrade Forscan Issues - Help!
agolder
2017 Mustang GT
Yesterday I did a 4" to 8" upgrade using HellHorse plug and play kit. The initial installation was a snap and I was able to complete the whole thing in under 1 1/2 with taking my time to check and double check everything. But when I tried to reprogram using supplied ELF 237 USB adapter and Forscan software I am greeting "Unable to connect to vehicle" error. I check all of the setting and watched a few YouTube videos and from what I can tell all of the seeting are correct. Forscan sees the ELF module but that's about it. Could the USB ODBC II adapter be faulty or is it something I screwed up. If I cant program the unit myself, what are my options? Would a dealer handle the mod?
Thanks,
Alex Golder
Bikeman315
Myrtle Beach, SC
Ira
Thanks,
Alex Golder
I'm not a Forscan user but knowledgeable enough about computers to always suspect anything mechanical when it comes to connections errors. Give Hellhorse a call tomorrow to confirm. You should not have to go to a dealer for this.
In the meantime, give this a shot.
https://www.forscan.org/forum/viewtopic.php?t=3375
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Dealer likely won't touch anything most likely, the guide Bikeman linked should help to make sure the OBD tool is actually being detected/supported by your computer.
It could be an issue with your specific one as well, not sure which you have but here is the one I got when I was looking for a cheaper/wired one for a module firmware update before: https://www.amazon.com/gp/product/B07S7W14X9/
Has given me no issues so far.
Thanks,
Alex Golder
Did you reach back to Hell Horse for advice?
agolder
2017 Mustang GT
I only completed the install yesterday. Will ping HellHorse tomorrow during business hours. Sounds like this is one-of issue. I also ordered a OBDLink MX module. If it worked I'll know its the ODBC II adapter,
agolder
2017 Mustang GT
I only completed the install yesterday. Will ping HellHorse tomorrow during business hours. Sounds like this is one-of issue. I also ordered a OBDLink MX module. If it worked I'll know its the OBD II adapter,
So the issue turned out to be a faulty OBD II adaptor. I was able to reprogram the unit and now it works as advertised.
I also upgraded it to Sync 3.4 with a USB. The only down side to doing this upgrade is that I no longer have GT Performance the theme. Oh well, I’ll just have you used Shelby theme instead. lol
