Stumbles at idle
Mrhavasu
So Cal
Terry
GT350
I am thinking this may be normal, but gonna ask. So my car will stumble a bit sometimes
after first starting it, only at idle and the car is warm. Never does this while underway and does not do this again if I come to a stop and idle. It has never died and no check engine lights.
100 percent stock, Normal?
Thanks
J. Kidd
Suffield, CT
2016 Shelby GT350 / Track Pack
I notice this occasionally as well....more like the idle drops a bit low an then gets kicked back up. And usually just during the first few minutes of driving. Never had an issue.
mephim
OKC
2016 GT350 Track (gone), 2019 GT350 (gone)
Want to report that I was dealing with this for at least a year. It turned out to be the Evap canister purge valve had failed in the open position. This was causing small misfire counts across all 8 cylinder, leading to low idle and stumbles on startup. I was also having long crank issues after refilling fuel.
hoping this helps someone
Postal Bob
Long Island, NY
Bob
2019 Shelby GT350
I notice this occassionally. I chalk it up to the fact the the gas sitting in the fuel lines on the engine, heat up after turning off the car, and create a slight, temporary vapor expansion. You ever look at your intake air temp when the car is sitting idling during a hot summer day? My typically will go above 150°. Ever see a plastic storage gas contaner that's been sitting in a hot garage? It starts to expand like a balloon. So the same thing happens in your car's fuel lines after you turn off your car, and the engine's heat continues to heat the fuel lines. If turned back on within a few minutes, you'll notice the stumble. But if left off long enough, everything cools down and the gas pressure in the fuel lines goes back to normal.
Btw, because of the heat generated by this engine, after doing some spirited driving, when I arrrive home I open up the hood. I leave it open until everything cools down before I put it away, or cover it back up.
Nfs1000f
Upstate NY
Neal
2017 GT350 & 2019 Ford Fusion SEL Hybrid
Yes
MCS
SW Ontario
Michael
'24 DH Premium
I had this issue after the Supercharger was installed. Turned out to be 2 plugs were faulty.
