Ls_Eater
- Dec 9, 2017
- Apollo Beach
- Parker
- 2018 Magnetic Metallic GT
- Vehicle Showcase
- 1
I've searched and searched, and I did find quite a bit of relevant information as to non-functioning active, caused by frayed wires (Which I myself have just replaced), on both Modified as well as stock vehicles.
After replacing the Pigtails myself, the active is still non-functioning, however, if you examine the tips while the car is off both are fully open (as expected), however upon starting of the vehicle the driverside closes and the passengers stays wide open, and shortly there after you receive the "Exhaust mode Selection is Unavailable".
I've attempted to "poke" the Driver/Passengers side and the driverside does show movement, where as the passenger is rock solid in its place.
I think it's safe to assume that my Passenger side actuator is stuck, I'm curious if anyone has ever fixed a stuck actuator or even attempted to disassemble it to reset the spring?
I WOULD take it to Ford, however they've already made it clear that they will not be covering this exhaust work under warranty.
