- Mar 13, 2016
- Titusville, Florida
- Website
- www.facebook.com
- Tommy
- '15 GT PP
Jim,
I'm sorry you did not have the same experience with your pads that all our other Customers have.
Your experience is very odd. The stock PP pads, while very good, I was able to get them to fade at Thompson and that is on a simple track and peak speeds were only 125. It's possible my style uses more brake than your style would. At Palmer even with the uphill into T1 I had issues on the stock pads getting my speed down, even with the extra compression from the hill I couldn't get into ABS with them on the P-Zero's. I tried a set of DS2500 Ferodo pads on the Daytona School Course on my current BFG Comp 2's and even though they are rumored to be the actual OEM pad I was not impressed with the bite at all and again was getting fade.
I ran R10's this past weekend at Daytona for three days, ABS on demand, braking twice a lap from 140+ for 30 minute sessions. No fade, excellent bite, braking at the 2 marker into the bus stop and braking after start finish into T1 mainly because of lack of grip and stock suspension making it interesting. I barely have any pad wear on the R10's. My ride check coach could have used a Hans during braking the bite is that violent
A similar car to mine was there on R10's and RE71's and needed slightly more brake but he was also able to brake harder and carry more speed. I also run brake cooling.
We still recommend R10's on the GT and R12's on the Shelby's. If you are on a Cup tire or anything approaching an R type compound you want to move up to a R12 (Sticky)/R16(Really sticky) on the GT and R16-R18 on the Shelby. A real R compound you would want R16-18's on the car. Obviously you run a big tire upfront that is a track compound you will want to utilize a R18 because this assumes you have suspension and tire footprint to use it. This is just a guide, driver style also impacts this, as does the course.
[MENTION=18475]Gatorac[/MENTION] You mentioned something where your braking data files surprised you. Do you care to share that information? It sounds like while you didn't feel like you were braking as hard on the R12's your data suggested otherwise :shrug: Did this cause you to over-slow at corner entry? Maybe you were over-braking combined with no brake cooling to cause the caliper flex leading to the tapered wear.
Please let us know if there is anything we can do to help :cheers:
