Stage 2 ProCharger kit with P-1X (901 rwhp)
Discussion in 'Forced Induction - 5.0L V8 Engine' started by ProChargerTECH, Jan 15, 2019.
  1. whatsup62
    whatsup62 Well-Known Member
    Vehicle(s):
    2015 Mustang GT PP
    Sep 16, 2015
    Jupiter
    1,939
    450
    Rating:
    100%
    7   0   0
    Ok..so the [email protected] psi was in the 3.6 pulley...correct? If so you should be close to 900 on 3.4.
  2. Rodsaleen
    Rodsaleen Well-Known Member
    Vehicle(s):
    2018 Orange Fury Mustang GT
    Aug 1, 2017
    Kansas
    195
    72
    0   0   0
    No the 867 was with the 3.4 pulley.
    whatsup62 likes this.
  3. AZ18yote
    AZ18yote Well-Known Member
    First Name:
    Bryan
    Vehicle(s):
    Nov 24, 2017
    Arizona
    1,216
    404
    Occupation:
    IT Systems Engineer / Consultant
    0   0   0
    Do you mind elaborating on this a bit?
  4. Jay-rod427
    Jay-rod427 Well-Known Member
    Vehicle(s):
    2016 GT C/S
    Jun 8, 2016
    Kansas
    2,154
    775
    Rating:
    100%
    3   0   0
    He means either blower is capable of exploiting the limits of the stock engine before goes boom.
    DTeal23 likes this.
  5. 80FoxCoupe
    80FoxCoupe Well-Known Member
    Vehicle(s):
    16 GT, 80 Fox
    Mar 28, 2018
    Cincy, OH
    1,016
    503
    Rating:
    100%
    3   0   0
    We need a 2019 6g track day.....
    Kep4 and Rjames18 like this.
  6. 9secondko
    9secondko Well-Known Member
    Vehicle(s):
    2003 cobra
    Jul 4, 2014
    Irvine, ca
    1,903
    967
    0   0   0
    Um... boost = pressure.
    PSI = Pounds per Square Inch.
    Use the headers if you are in a state that can accept them.
    It’s not so much about the max power, but getting the same power with less boost. Headers will help with that since they ease the flow of exhaust pressure. With the added intake pressure from the blower, a more efficient outlet makes tons of sense.
    The current GT manifolds are great. But some aftermarket headers are notably better.
    Less pressure = happier engine over time.
  7. sKyZ
    sKyZ Well-Known Member
    Vehicle(s):
    2019 GT PP, 1994 GT 'Vert
    Oct 30, 2016
    NC
    155
    43
    0   0   0
    What shop was the pull made at? It looks familiar.
  8. BlueCollarDaily
    BlueCollarDaily Well-Known Member
    First Name:
    Shawn
    Vehicle(s):
    2019 Mustang GT 400a
    Jan 8, 2019
    72058
    555
    82
    0   0   0
    I had been trying to get a P1x complete non tuner kit for a 19 a while ( so I could use warranty ) finally gave up and ordered a TVS 2650 :( sad day I loved my Prochargers I still have my -94 on a BBC and it's perfect ....
    For a street car I disagree a bit with ProchargerTech in the same way he dismisses boost as a restriction of flow ( especially with VCT) I dismoss that mid range power he says you loose running a larger blower turned down, in that on most street cars especially oeaky Coyote A10 talk gear ones....with nominal traction ( tires and less than favorable surfaces wink wink ) the lack of mid range with an A10 keeping her right in the sweet spot once she reaches 7500 is better....until your NOT traction limited and can launch full tilt and not spin a lick I'll trade low end for peak power esp in a combination ( Coyote A10) that quite literally has that build philosophy....that's why people can take a bone stock 19 A10 to the track and run 11s on all seasons...you could put a 392 hemi at same weight and not do it because wheel spin would become an issue right away.....while your over there stomping it and chirping tires they would be boiling them....extrapolated out to their Whipple vs your peaky low mid range but super high speed HP.......I'll take to big a blower I and the chassis grow into on most daily drivers........because those Dyno numbers you lose in mid range torque directly correlates to making your car hook ....till you can use it all and need more.....just a bit of nuance ....if I was gonna drive around on true drag pack 15s and a drag radials sure give me that " punch" otherwise I'll take the low torque high peak numbers and usually lower IAT of a slightly larger blower turned down ....
    All their new line up is SO stellar sucks I couldn't get a tune for them for P1x or D1x....and my 19....
  9. gimmie11s
    gimmie11s Well-Known Member
    Vehicle(s):
    Murica!
    Mar 2, 2018
    SoCal
    983
    538
    0   0   0
    You picked an entirely different blower because you couldn’t get the blower Co’s tune?
  10. BlueCollarDaily
    First Name:
    Shawn
    Vehicle(s):
    Jan 8, 2019
    72058
    555
    82
    0   0   0
    Yes.....because if you don't use the tune from procharger there is no warranty....now I have 3/36k on a new 19 with 1300 miles on it......
    Now it's also hecause I have a lifetime of GM experiance and changing platforms and with the issues on the Gen3, I'm more gun-shy had it been say a LS I would have rolled the dice as I already have spare parts and the knowledge of building and tuning them....it's quite a steep learning curve from pushrod LS to 4V double over head cam with VCT when browsing thru my stock tune...hehe....
  11. BlueCollarDaily
    First Name:
    Shawn
    Vehicle(s):
    Jan 8, 2019
    72058
    555
    82
    0   0   0
    I may not have been clear enough sure I wanted a D1x ( or p1x)complete with their tune so that I could buy the power train warranty which is a stipulation of said warranty......because I am new to s550 and the Coyote in general and with the issues on the Gen3 I would have felt a bit more comfortable with some protection whereas with a GM product I would have rolled the dice on a tuner kit and hooked my MPVi2 up and got started with the largest pulley they offer......and worked down....
    So I felt compelled to buy a different vendor blower kit and in doing so received a 3/36 on blower and up to $16,500 coverage on power train using their stock canned tune which should stress the combination, find weak points, while giving me a little more time to learn to log, tune, and gather parts for a forged short block at a more relaxed pace....lol....
  12. gimmie11s
    Vehicle(s):
    Murica!
    Mar 2, 2018
    SoCal
    983
    538
    0   0   0
    Fair enough... makes sense.
    My 2018 got twin turbos with 3000 miles on it.
    If she blows, she blows and I’ll have to build a motor.
    80FoxCoupe likes this.
  13. BlueCollarDaily
    First Name:
    Shawn
    Vehicle(s):
    Jan 8, 2019
    72058
    555
    82
    0   0   0
    That would normally be my attitude but I have reason ( in my inexperienced mind) to believe that I already have a few issues ....so I'm at least , I hope buying time for this steep learning curve and gather a few parts......omg which twins you have high mount? My God what that must feel like
  14. Leshik
    Leshik Well-Known Member
    First Name:
    Oksana
    Vehicle(s):
    18 GT PP1 10r80
    Mar 29, 2015
    Staten Island
    216
    36
    Occupation:
    CCRB
    Rating:
    100%
    1   0   0
    So basically if u want anything above 800-900 whp P1x will do the job and still maintain that nice midrange torque for daily car? And if any thing above 1000 d1x is better?
  15. whatsup62
    Vehicle(s):
    2015 Mustang GT PP
    Sep 16, 2015
    Jupiter
    1,939
    450
    Rating:
    100%
    7   0   0
    Kinda..800-900 is basically maxing out or at least at the very top of the range for the P1X.... 800 up is where the D1X starts. So if you are in the middle like me its a tough choice. I have the P1 not X and am at 800...getting all I can out of it currently with out over spinning it. Was torn between P1X and D1X but knowing I have a forged short block in the future ready to go Beefcake talked me in to not limiting myself and giving room to grow. With that the only thing holding me back will be a fuel system.
Loading...
Share This Page
