Squealing sound when braking?
USAF
#GTFOsquad_0047
Philly
2015 GT, 1993 GT
My dealer told me they could not dublicate however it did it twice in the parking lot as I was picking it up. Not happy..... Along with them doing an alignment and my rear pass wheel is so towed in at the top I'm sad to drive the car because people would think I'm trying to stance the car out
POOPonYOU
I Do Stupid Well
Paramount, Ca
2015 Race Red GT Premium
Contact FordService on these forums to escalate your complaint. Good luck.
Guard
Senior Member
Los Angeles, CA
2017 Ford Mustang GT
Same shit happen to me... Ford service made me a case number and got me in touch with the regional customer service manager/director ... He pretty much reiterated the same thing the dealer said... No help what so ever..
klumpikat
Chick driver
La Jolla, CA
Liz
2015 GT Premium, 2023 Mach 1 Premium
What does "towed in at the top" mean? I recently learned what "stance" is, so it sounds to me what you are describing basically is one poorly installed tire, yes? :confused:
If I were you, regardless of brake squeal (which is just cosmetic), I would make an appointment with another dealership immediately. Your safety is much more important; this is a performance vehicle, not a decorated Honda bopping around the neighborhood. Also, perhaps a different dealership will solve your brake issue as Ford is obligated to do so. :ninja:
Good luck and please be safe. :cool:
POOPonYOU
I Do Stupid Well
Paramount, Ca
Take your car to McCoy-Mills Ford in Fullerton. Call Joe Green so you can make sure he's there when you take your car.
GT Pony
Pacific NW
I think he means "toed in" at the top (wheel alignment jargon), which means the top of the tire is tilted towards the center of the car way more than it should be. If he can see that one of the rear tires is tilted in more than the other, then the alignment is probably off. Of course the best way to know it to have the alignment checked on a machine and adjusted if out of spec.
klumpikat
Chick driver
La Jolla, CA
Liz
Thank you. :D
Yeah...If I saw that I definitely wouldn't be driving my car around with a tire in that condition, and would take it elsewhere for service.
cush
Littleton, Colorado
2015 GT Premium with PP, Guard Metalic
I'm not an alignment tech, toe is not the same as camber which is what a number of people are describing here... Toe, if you were looking down from above the car would look like the wheels/tires are pointing in toward the center of the grill (toe in) or out toward the headlights (toe out). Camber when viewed from either the front or rear of the car would look like the tops of the tires/wheels are tilted toward the center of the car (negative camber) or if they appear to be tilted toward the outside of the car (positive camber). That's my take.
GT Pony
Pacific NW
^^^ Yep, that's correct. I didn't use the right terminology ... if the top is tilted in/out it's camber.
USAF
#GTFOsquad_0047
Philly
2015 GT, 1993 GT
@guard....are your rear wheels cambered in at the top??
Yes cambered not toe...
FordService
Ford Customer Care
Dearborn, Michigan
Mustang
Hey guys,
Although it may not be the ideal option, have you tried getting a second opinion at another local dealer? As dealers are independently owned, there may be one more familiar with the issue. If this is a potential option, send over a PM. I'll enlist additional assistance on my end. :)
Jeff
Qwkynuf
Washington
2015 Ruby Red Mustang GT
I am really curious whether anyone whose car was built after the cutoff date on the TSB is experiencing this problem.
I have seen several people post that their dealer said that they couldn't duplicate, and weren't going to do anything about it - and several of those people were asked about their build date with no response.
My car was built in October of '14 and had dump truck level brake squeal. The TSB repair was done on my car early this month and I have put over 1600 miles on them without a single peep.
I would guess that the parts that were replaced on my car would have been blended into the production line around the date of the TSB, so that newer cars would already have them?
POOPonYOU
I Do Stupid Well
Paramount, Ca
Hey guys,
Jeff
Hey Jeff why the hell is your company trying to piss off it's customers? You have a TSB that applies to your customer's cars based on a build date and a noise that we've complained about but you're still not going to help. All this anger and frustration because your techs couldn't replicate a noise after a 2 minute car drive? Some have even provided a video. These dealers get reimbursed for warranty work. :frusty:
USAF
#GTFOsquad_0047
Philly
2015 GT, 1993 GT
I just had the service writer tell me cars do squeal in reverse ....then I said again my car has a TSB and the other writer says thats really nothing, that just helps the tech find the problem/fix
rbeaudo1
Michigan
Randy
2019 Mustgang GT Premium A10 VB Roush charged
When I took mine in I had a copy of the TSB with me and it states to replace pads and rotors my dealer just ordered the parts did not even test drive it
