Square setup or NOT
BA939P
Canada
Dante
17' GT350 & 14GT
My stock tires are almost run out, so I am looking for new tire setup.
My wheels are stock performance pack wheel, and thinking about 275 all around.
Is there any pros or cons of square setup, and any tips of tire rotations?
Thanks guys:cheers:
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
You can run the square without issues, and or do the 9.5 all around use a 5 mm spacer upfront and 275 on all 4 corners.
BA939P
BA939P
Canada
Dante
17' GT350 & 14GT
I'm also running with 1inch spacers all around, what would be the best matching spacer width without rubbing?
Thanks :thumbsup:
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
There's a few threads about this already. Long story short; Square is great for the track and creating a balanced handling car as well as being able to rotate
the tires. Staggered rocks if you have a lot of power(more than stock), go to the strip or want that big booty look.
I DD mine(for the time being) and track it as much as I can. I have square sized wheels but staggered tires. I wanted options if I were to change my mind.
Good luck:thumbsup:
BA939P
BA939P
Canada
Dante
17' GT350 & 14GT
Good luck:thumbsup:
thanks man. your advice is so helpful:thumbsup:
2morrow
NorCal Bay Area
Todd
'16 Mustang GTPP
No probs brotha, that's what were here for. Post up what you end up doing and enjoy the ride! :cheers:
Stuntman
SoCal
many
You'll have very poor steering response running 275s on a 9" front GTPP wheel. Find a set of rear wheels to run square tires on square wheels.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I wouldn't say "very poor". It depends on the tire (sidewall stiffness), and 1/2" difference at the wheel isn't all that much really.
Noize
Ricer
Nashville
2013 Evolution X
Is there any way you could fit a 295/35/19 square setup on 10.5" wheels, or is that asking too much of the GT fenders?
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
No you can do it.
Stuntman
SoCal
many
It's also subjective but I've never driven on a setup with a tire that much wider than the wheel and had it be anywhere near as responsive as a properly sized tires where the tread was similar if not narrower in width than the wheel.
Go to a car show and you see many setups like this. Go to a racetrack and you won't. AutoX is a different world that I'm not familiar with and maybe it's lower speeds don't require the same demands due to lower speeds, but you may see fat tires on narrow wheels work there..
TrackpackGT
NC
15 Mustang GT PP
Love my 275/40/19 square setup, just would like some lighter 19x9.5 or 19x10 wheels. The PP wheels are crazy heavy. Oh, and not to mention the benefits of tire rotations....
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
There are a number of lightweight options that will drastically cut down the weight for you up to 10 lbs per corner.
40 lbs unsprung weight reduction
400 lbs sprung weight reduction.
TrackpackGT
NC
15 Mustang GT PP
Oh, I'm aware of that, just don't have the $$$. Thanks for letting me know about sprung vs unsprung. I didn't realize it was that drastic. Definitely on my to do list.
