Spinning to a 10.33
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
Spinning to a low 10. Hit atco tonight. As usual. Prep sucked. Best run of the night was a 10.33@135. Just got my 18 manifold installed. And was doing some data logs for Lund. The run pictured had a 10.1 written all over it. Til I blew the tires off on the 1-2 shift. Think im going to try cecil county. Before the season is over. Not having much luck with Atco this year. The car feels like a monster with the 18 mani.
mmacoyote
NY
2018 s550
very good 60ft, only picked up 27mph after the 1/8th if you did have traction and didnt spin like you said mph would have been lower.
Tommy V
Brookly park Md
Tommy
If u can get that 60 down to a high 1.4 u def have a 10.0.run,maybe a 9.9??What is your best mph so far?
bluebeastsrt
bluebeastsrt
Oh boy
New Jersey
BigD
Best mph is 136.5. I usually sixty in the low 1.5 range. Since I put the supercharger on. The car is spinning the 1-2 shift on every run. Gotta get that figured out. Its still on the stock suspension. So ill probably make a few changes there this winter.
Tommy V
Brookly park Md
Tommy
I think u have different gears then me,i have 315 but with mt et street ss i am getting 1.45 60 ft with wery little spin in 2nd.We did have good prep though.I went 9.8 at 142 but i also.am e85.You still on the 3.6 pulley right now?
kcc0521
Falls Church VA
Bo
2015 Black GT PP
What tires are you running? What is your setup? What type of burnout are you doing/
bluebeastsrt
bluebeastsrt
Oh boy
New Jersey
BigD
your manual right? Im stalled auto on a 3.55 gear. 93oct. 3.6 pulley. And she’s a heavy girl. 4200 race weight. Id like to see a 9.99-10. But unless I can get the 1-2 shift worked out. I wont sniff that time. DA last night was barely negative. So I should pick up a 10th just do to the good air moving in.
Tires are 305-45/18 NTo5Rs running 15psi cold. And using a 5 second burnout.
Tommy V
Brookly park Md
Tommy
Nah i have an auto now lol,need to change my sig.I have a fti 3800 stall convertor.Before i went e85,i did some testing and using ms109 i ran 1 to 2 tenths quicker then using 93 and octainium,but its expensive.Got about 2 more degrees of timimg.What size wheel u running on the back,i never had much luck with the 19 in wheel even with a good radial.The 17 in worked much better.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I set of MT tires or possibly a shorter burnout might help. I was spinning mt ET Street r tires and realized my burnout was too long.
Tommy V
Brookly park Md
Tommy
I think he is running a 18 in wheel with nto5r drag radials,i thought we always had to do a good burnout with them but we were manual cars back then.
bluebeastsrt
bluebeastsrt
Oh boy
New Jersey
BigD
Yep 18 inch wheel. The nittos like a big burn out.
Tommy V
Brookly park Md
Tommy
Its got a 9 in it kcc ran a 9.9 on the 3.6 pulley,i think he had ms109 but he may have done it on 93/octanium.How much timing u seeing up top,i think u will need 21 degrees with that pulley
bluebeastsrt
bluebeastsrt
Oh boy
New Jersey
BigD
Ill have to check em. Im at work right now.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I went a 9.9 at around 138-140 in good air on 3.6 pulley, full weight car with performance pack brakes on 93 and octanium.
