Speedometer off after diff (pumpkin) swap
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
I went from a 3.31 / Trac lok to a 3.73 / Torsen.
Car was originally a non-PP car equipped with 235/50R18 tires and now it has 285/35R19 tires. Not a huge difference, 1mph at 60.
When I first installed the diff, the car pulled power over 3k rpm in 2nd, 3rd, and 4th gears. Did not bother trying 5th or 6th, but I would assume the same issue would persist.
Based on what I read here, in Forscan under BdyCM I changed the axle ratio to 3.73 (hex 0175) and the tire diameter to 2072 (hex 0818) per the spreadsheet in this thread. Then I did the PCM re-learn.
Car runs fine, no pulled power. I can do a 1-2-3 pull w/o issues.
The issue is that my speedometer is 5mph under. Changing the tire diameter to 0818 and re-learning the PCM will have it work for a bit, then it will go back to being 5 under. The values in Forscan do not change back; the speedometer simply no longer reads the correct speed. I am using my phone for verification. For comparison, my Bronco is within 1mph of the phone in the same areas at the same speeds.
Car does not have a tune.
Any suggestions?
I am thinking I will need to get a Procal but was hoping this was fixable with just Forscan.
Pass along info:
Searched and found some threads relating to S550 rear gear changing and tuning. What is in the thread content is not all related to a specific S550 model or year, BUT what is discussed may help to answer some questions or maybe provide some more guidance:
https://forum.hptuners.com/showthread.php?75313-2018-Mustang-Gear-Ratio-Change
https://forum.hptuners.com/showthread.php?64135-2015-Mustang-GT-Speedometer-Calibration
https://forum.hptuners.com/showthread.php?68888-17-Mustang-GT-Traction-Control-Advancetrac-Question
MrMike
MrMike
US
MrMike
MrMike
US
It is on the newer cars unfortunately
I was afraid of that. Unless somebody pops in with something I obviously missed, I'll be calling Ford Performance on Monday to talk about the Procal.
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
I bet you could use pcmtec for this, if it’s all you want to do, might be more cost effective in the end.
MrMike
MrMike
US
Mike Pfeifer
Wesley Chapel, FL
It does show in AUD, but I think it will convert at purchase or something like that. It’s been a couple months since I looked at it. It does require a different cable, there is one that’s like $140 I think, and the pcmtec conversion comes out to like $120 if I remember correctly. (Assuming you only want to use it on the one single car and don’t want custom OS.)
Mike Pfeifer
Wesley Chapel, FL
@tdstuart would have some better recent experience with what is needed specifically to get it working. He just went through it a few weeks ago.
MrMike
MrMike
US
Good info.
I looked at HPT too but their MPVI3 with a credit is not cheap either. Is VCM Suite included if you buy the device?
I don't own a Windows laptop w/a functioning battery currently, just an old ThinkPad that needs to be plugged in.
I'll sleep on it but I like the ability to use the Procal as a stand alone diagnostic / tweaking device. Also like that FP will back me up if it doesn't work out for some reason.
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
I had the same gear ratio so I didnt have to change anything. There is a special function for speedometer calibration that hptuners has, same type of function like crank relearn. PCM tec doesn’t have functions like that as far as I know but you can change speedometer settings in the tune file.
Ive tried playing with the speedometer calibration but I would need to watch the digital readout on a logger in real time to tell if it’s accurate or not.
The car has some learning features for the speedometer and tire sizes. I’m not sure how it identifies that it needs to make a change and how it determines what the correct values should be.
Later tonight I can pull up the options you would have with pcm tec. You could probably disable the learning but I don’t know if this is the technically correct route or if there may be another value you have to change.
Mike Pfeifer
Wesley Chapel, FL
Good info.
All good points. Just wanted to toss something out there that you might not have considered is all. I’m sure whatever way you go will get you where you want to be. It’s too bad that forscan alone cannot do it.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Just pointing out that the way these things work is different on the 18-23 cars compared to the 15-17 like you have
MrMike
MrMike
US
Agree for anyone else who may find this thread, but mine is a 16.
MrMike
MrMike
US
At the risk of being boring, this makes me lean even further to the Procal lol. I've read almost all of your custom tuning thread, and that is not a rabbit hole I want to go down.
