roushed_daily
- Nov 17, 2016
- Chicagoland - NW Indiana
- 2016 GT PP w/ Roushcharger
Replaced the broken bolt, noise remains.
Steeda 555 4443 - Adjustable Diff Bushing Insert Kit, using red inserts
^^^^I'm using the black inserts.
I have the same exact vertical links also. How much you want to bet, that's what's making the noise? It's a safe bet since they're straight spherical bushings with no give like a delrim one would. I think I might throw the stocks back in and try again. If that's what it is, I'll try to grease up the metal on metal connection again and put them back in.
I think I might also take the spring out, grease between the coils, grease the top of the isolator boot, and put it back in.
I'll keep you posted.
But I'm really suspicious of that end link.
Thank you for this info. The only thing I have that you don't out of that list is the Steeda IRS Subframe Braces - Fastback. That would be really easy to take off, but if you're getting the same noise, I'll concentrate my efforts elsewhere.I have a sound coming from the rear passenger side as well and also a noise and feel as if I'm running over a large pebble with the tire when taking left turns. I am trying to figure out the noise as well. My suspension guy torqued everything to spec on BMR's site for the parts.
I have BMR and stead parts installed as well as a 3.73 Torsen diff:
BMR TR005 - Adjustable Toe Rods
BMR TCA045 - Vertical Links
BMR BK005 - Bearing Kit, Lower Control Arm, Rear
Steeda 555 4438 - IRS Subfram Alignment kit
Steeda 555 4437 - IRS Subfram Bushing Support System
I have talked to Kelly at BMR about this and that's when he recommended making sure my tech tightened everything down to torque specs which we did and I'm still getting the noise.
From inside the car it sounds like its coming from rear passenger side upper corner panel area when it makes the rubbing noise and only does that when I go over bumps while in the road, and the rolling over rock - pebble noise (like a little thunk/pop) happens mainly when I take left turns.
still trying to find the cause of the noise. Wondering if its caused by the adjustable toe rods and knuckle bearing, but the OP here says he replaced that with the ford performance knuckle bearing. I have these bearings as well but haven't installed them yet.
