So we get a freee filter and wrench
mkonrad
Austin, TX
2016 GT350 Oxford White
This still feels like a diversion, like giving Ford Explorer owners a new tire pressure gauge, or Ford Pinto owners a new gas cap. Or perhaps it's an excuse to smack a poorly behaving dog on the head with a newspaper because they aren't following the posted directions.
But there's a chance it's because I had no difficulty tightening it to 18 ft lbs, was able to read the instructions, and am simply sore I can't return my wrench to Amazon. Something tells me I'm going to be let down no matter what wrench we get.
Tomster
Beware of idiots
Tom
I think you are on the right track. By supplying a tool to go with the unusual requirement to torque the filter down so hard, Ford is dodging liability. I wouldn't want to be the guy who changes his oil and then blows a motor because his filter came loose.
Even at the high torque setting, I periodically check to make sure the filter is still tight. Without documentation, it would be a "he said, she said" proposition.
kartguy898
Ottawa, Ontario
2016 Shelby GT350 / 2016 F150 FX4
kartguy898
Ottawa, Ontario
Etis is back up -
Outstanding Field Service Actions
16S40 - ENGINE OIL COOLER TUBE ASSEMBLY REPLACEMENT
17B04 - COMPLIMENTARY OIL FILTER WRENCH
We will check for outstanding service actions on your selected vehicle, using your detected country, if this is incorrect you may not see the right information.
We have detected that you are in the: Canada
shelbyman
Huntington Beach, Ca.
Sandy
2016 GT 350 Track Package White w/blue stripes
swlacobra; . on my 16 they struggled with a strap wrench to get it torqued correctly.[/QUOTE said:
:lol: this is hilarious....strap wrench:shrug:
Epiphany
Global
I like to disassemble things.
This better be a socket style cup that merely requires a 3/8" extension/ratchet to tighten...
machsmith
somewhere along the river
Jim
Honda Minis
Sounds like the change was made after the last of the calendar year 2016's were built and anything built in 2017 calendar year will have the change.
Wonder what they actually changed? I'm gonna guess the only change was in the filter itself. Could have possibly enlarged the male threads, but don't know how much that would help, and don't want to cause any metal to metal contact in that area. Possibly just the seal on the filter. I'd be interested in finding what the revision is.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
As you read through it, shows oil consumption of a quart per 500 miles is possible...
My bullshit filter translates that to "oil consumption of a quart per 500 miles is possible if you even remotely use the vehicle as intended"....
Honus
Southern Tier, NY
2016 RR GT350 Tech
There's no way Ford can be skirting liability for this by giving the owners a wrench. If they nuts it up, they can't say, "The customer didn't tighten it after the oil change!!!"
fpa1974
GA
'19 GT350R
Or even stuff like "1 quart per 500 miles is normal regardless of how you use the car". I am afraid this will become a standard excuse in case excessive oil consumption occurs (and yes, 1 quart every 500 miles is rather excessive at least for normal driving).
Strokerswild
Southern MN
Things With Wheels
A quart every 1,000 used to be acceptable....back in the '60s.
