Single Brake Light Bar Stuck Bright
wildcatgoal
@sirboom_photography
TBD
Not my car, but yesterday I saw two different Mustangs with the inner-most tri-bar on the left brake light lit up as if the brakes were being pressed/turn signal was on. It was super obvious, as all the rest of the 5 tri-bars were just in running light mode and when these individuals would brake or use a turn signal, they'd light up appropriately. I thought to myself, maybe it's a setting in their particular cars where they can run a rear fog warning light similar to what I had on the cars I used when living in Europe, but neither of these cars had Canadian plates (some cars there have this feature).
Just thought I'd throw out that observation should anyone want to give their own car a lookover before their 36K warranty ends, or something. Just odd I saw TWO cars in the same day with this issue. That or there is some kind of light feature on the car I've not found, haha. :shrug:
Kong76
Turlock, Ca
2016 Ingot Silver GT
I just noticed this tonight on mine. Driver side middle tri bar stuck in brake light mode. Warranty ended in April.....
jeffmac179
Ocoee, FL
Jeff
2015 GT Premium - 50 years edition
Seems like my 2015 GT is having a similar issue. The inner most tri-bar on the passenger side tail light is stuck on brake-light brightness when the lights are on. Rest are fine. Just bumping this thread in hopes maybe someone has found a remedy? Don't want to spend $500-$900 for a whole new unit for one LED issue.
Kong76
Turlock, Ca
I had the exact same problem on driver side. No fix but a new tail lamp. Had my bcm reprogrammed for $135 and nothing. I bought a set of clean takeoffs from a member on here for a killer price. Look around.
jeffmac179
Ocoee, FL
Jeff
Thanks for the reply and the info. If it continues to annoy me, I'll look into replacing the unit.
H35
Ontario, Canada
2015 GT
Is a new taillight the fix?
I have the same problem, inner on the right stays bright
Dweisman429
Jasper, IN
Daniel
Similar issue here...except the outter bar on the left lamp.
I also bought a set of takeoffs for a very reasonable price and replaced it.
Not sure if the lamp could be repaired or not, but I'm not going to worry about it.
Dweisman429
Jasper, IN
Daniel
On mine it did for me anyway.
I bought them from a guy that did euros...but before I bought them, I swapped it out with a buddy's car to make sure. Luckily I had that option available
Jeg70
James
15 mustang gt
I am having same issue with my 15 GT PP (orig owner 38k miles) with center tribar of left tail light always brighter than the remaining LEDs. Are there any other fixes besides full replacements? Disconnecting the battery had no impact? Thanks
Rob_GT
Chile
Rob
Mustang GT 2016
I know it's been awhile but did you fix the problem? I have the exact same issue with my 2016 GT.
Skye
≈39N
"Skye" Mach1 N2144
Same here I'm afraid. The OP has not posted in a few years.
But hopefully :please: , the bump in both threads will bring some attention and feedback.
jeffmac179
Ocoee, FL
Jeff
A years-later update:
I ended up buying a whole new tail light assembly for the passenger side. Found a used OEM one in near perfect condition on eBay for a couple hundred bucks. They're probably a bit cheaper now if you can find one. Haven't had any problems with either tail light since.
