Show me your Fore setup!!
Crackerjack17
WV/Maryland
2017 GT PP
Exactly how does your led know the pump is actually working? !im assuming you'll tie it in so when the pump has power, andthat's what's lighting your led. Just cause the pump has power does not mean it is working?
True. I'm going to wire an led light simply to let me know that the hobbs switch has triggered the second pump and the FC3 is outputting power. Whether the pump is actually working is another issue. Lol
pro 5.0
Canada
2019 Mustang GT
Why is everyone in fear of the pump not working in a staged setup, in a primary pump application the pump runs full time. A pump that is being cycled on and off under boost will have a far better life span than one that runs full time. The major issue I see being a problem is the wiring job bad connections and so on causing a failure.
RoadCone
Ohio
2016 Competition Orange PP
I just finished up my Fore system. I elected not to run the Hobbs switch on the triple pump setup. It was just one less thing to worry about. I don't think it's that much wear and tear to run the all the time for peace of mind. If it becomes an issue I will install the Hobbs switch later. I will know more about the noise and how it effects the regulator once it is finished and running.
There is some good information in this thread, thanks guys.
Tommy V
Brookly park Md
Tommy
Guys that are running the Fore system is it true that u have to keep close to a half tank of fuel because of not using the venturi system??I have heard this from guys that track their car!!.
pro 5.0
Canada
2019 Mustang GT
If you are referring to the small pick up tube that attaches to the bottom of the fuel hat, the Fore hat works just like the stock one. That tube is drawing fuel into the pump from the other half of the tank.
RoadCone
Ohio
I think he is talking about the white plastic hat that goes around the stock pump that keeps fuel surrounding the pump when it is on.....
kcc0521
Falls Church VA
Bo
2015 Black GT PP
You are correct. Wow are curious if the pumps will run dry under acceleration or hard cornering with less than half a tank of fuel.
higdominator
Central Oklahoma
2016 GT PPP
Cornering, yes. Hard accell, depends on fuel level. I always ran at least 1/2 tank at the strip in my 15 with an open hat. There are solutions though. You can run a surge tank and that will eliminate starvation due to G forces.
DiEzel
GTFO OG - The Professor
San Diego
Ray
Oxford white GT Premium PP
That's a lot of unnecessary heat running all three constantly. Two constant, and 1 switched is ideal.. Two pumps can usually supply enough for 1k.
My last fore setup I was running 1 constant, two switched. Worked awesome. Lund agreed.. We were doing 16psi on stock bottom, Fuel trims always looked stellar.
New setup will be two constant, 1 switched. Haven't installed.
BDMACH1
Ravenna, Ohio
Bob
2016 Mustang GT/CS
Mine drives around on the primary pump, and then the 2 Walbro 465's are fired on the Hobbs switch.
RoadCone
Ohio
This is my first PD supercharger. Will it constantly be in and out of boost? If so it would always be on/off.
DiEzel
San Diego
Ray
You tend to get into a couple psi with regular driving, but the hobbs are set @ 5psi.
They're not constantly going on/off, but it's okay if they do. It's by design!
RoadCone
Ohio
I called Fore on this. They said one stock pump is about 60watts, running three is over 200 watts. They said this is extremely hard on the wiring. I will be installing the Hobbs switch. Thanks for the information guys. I thought I would share...
Glockmeister
IN
2016 GT Premium, Auto
z06psi
Evans, GA.
Andrew
The pot stirrer
In the Z06 I run a triple pump into a -10 and then Y block to two -8s through the rails and then both rails into the regulator back to the tank in a -8.
1200 rwhp later I have never had an issue and all three pumps run full time.
I will probably do the Mustang the same way. I just ordered the Fore dual pump. Got the upgraded TI Auto F90000274 pumps with the FC3 controller.
