Service advancetrac
Ericlp
Wisconsin
Eric
2017 Mustang GT
So after some spirited driving my car threw a service adcancedtrac code. Now my abs, air bag traction control and hill start are all disabled. I saw a few posts on this forum but none of them helped in showing where to look and what components could cause this. I'd rather not take it to a shop and fix it myself. Tried shutting the car off and on a few times but code still appears. Any tips?
Zero Bar
Arizona
Ben
2022 Mach 1
I used to have this issue with my 15' GT when hammering on it, when back to normal with key off/on but I did have to pull my battery once to get it to reset. Worth a try?
Ericlp
Wisconsin
Eric
2017 Mustang GT
Yea lll try pulling the negative off. I was messing with it today and then all of a sudden when I was backing up it went off again.
Buldawg76
Alabama,USA
2020 Ecoboost Premium, 76 FXE shovel, 77 KZ1000
Make sure the traction control connector/plug jumper next to left side of air box is in place and securely connected. If its loose or not making a good connection it will disable the advance trac and all the nannies, It's the plug they disconnect when doing dyno pulls to disable the traction control due to no front wheel rotation is being seen by the ABS when on dyno.
BD
This is the harness/connector being referenced in the above thread. Check the harness at the air box which may also be an issue if it has become disconnected... pictured in THIS thread:
https://www.mustang6g.com/forums/threads/traction-control-fuse.109035/
Check all fuses in passenger side fuse box behind kick panel AND the under hood engine fuse/relay box for any blown or loose fuses/relays.
Seeing you have a 2017, most likely this is your issue.... for 2015-2017's the common issues with advance trac/abs/steering warning light weirdness, check the rear axle thrust washer, see here:
https://www.mustang6g.com/forums/threads/abs-advancetrac-power-steering.162475/#post-3308430
Sweetface
Nashville
Scott
2019 mustang gt
Possible wheel speed sensor
Ericlp
Wisconsin
Eric
2017 Mustang GT
Are you aware of which fuses are r
related to the
Are you aware which fuses are related to traction control/abs. I checked the jumper wire and it's connected and secured. Checked fuse 28 under the hood also
websterzx10r
Connecticut
eric
2015 Mustang Gt PP 6 spd
Just had this happen to me July 2022. Had to replace right wheel bearing and Hub assembly. Abs wheel sensor on my 2015 Mustang Gt.
Zrussian13
Phoenix
Have you replaced the drivers side in the past? I've heard it usually fails first so I'm surprised yours was on the passenger side if it was the first to go.
websterzx10r
Connecticut
eric
I am the second owner so I have no idea. I brought the car with 30 thousand miles on it.
Ericlp
Wisconsin
Eric
2017 Mustang GT
Ok so I got codes pulled finally and it has codes for the left rear wheel speed sensor and tone ring as well as the steering position sensor. I replaced the wheel speed sensor think the hub is the best bet then?
Ericlp
Wisconsin
Eric
2017 Mustang GT
California
Tanner
2016 Ford Mustang v6
So I had this happen to me and watched tons of videos and got the idea of screwing with my e-brake. Lifted it up and down a few times and all the sudden the light reset itself. Not sure what the issue was, but it hasn’t been on since lol
