Service advance trac
Kayala
Kenny
S550
2019 mustang gt fbo
Service advance trac pops up when full throttle
I’ve try take advance trac all the way off and still pops up
Any ideas ?
no steering lights no abs no wrench light mo nothing but service advance trac when full throttle
Zrussian13
Phoenix
Full throttle or during excessive wheel spin? I've triggered that warning twice but I was spinning circles in the rain once and power sliding a corner the other time. After shutting the car off it never came back on. Haven't seen it from hard straight line pulls.
Kayala
Kenny
S550
Only at full throttle straight line
WItoTX
Houston
Kyle
'17 GT350
Pop your hood - check to make sure the jumper connector is totally secure and not loose - see here:
https://www.mustang6g.com/forums/threads/traction-control-fuse.109035/
Also check and make sure all fuses in the passenger side kick panel fuse box are secure (and none are blown) - and check all fuses in the engine bay fuse box as well.
^^^This first.
OP, we need more info, as Zrussian points out. I had a similar issue when I spun for a long ways at a track, car went into limp mode, exhaust shut, and wrench stayed on until I stopped. Once stopped, it cleared, good to go.
Kayala
Kenny
S550
I haven’t check fuse Ima check that when I get home , also trans (10r80) has been repaired recently I don’t know if that would have something to do with it
GaleGT
Hinesville, GA
Gale
2016 Mustang
Update us after you checked the connections and fuses.
Kayala
Kenny
S550
Check all fuses n connections and same thing .. but I disconnected the plug by the air box and service advance trac didn’t pop up ..
