Sct datalog paxton questions
Whtvans550
Houston
2016 mustang gt
so just have a few questions seeing if someone can help answer them regarding datalog and reading it. this is in regards to a supercharged car.
1. with spark advance under wot say 15 deg, do you use that max number and the -1.50 knock retard number together?
sort like 15 plus the -1.50 and get max 16.5 timing?
2. also what tables determine max spark timing? coolant, inlet temp and so on?
3. what the average max timing are you guys seeing with a complete stock auto car with say a paxton setup 3.6 pulley and 93 pump gas?
4. is there away to know thru datalog what the max timing could be under wot?
thanks
dubster99
Nor*Cal
2015 Ingot Silver GT PP
1. The spark advance number is the actual timing. The knock number means it's adding 1.5 degrees from the base timing to get to 15.
2. Not sure completely what tables it uses, but it definitely uses knock, coolant, inlet temp. There might be more.
3. On my car, I was seeing 16 degrees on shitty CA 91 oct, and the 3.8. Most guys with 93 tend to be in the 18-19 range on 93 and the 3.8, so with the 3.6 you're in the right timing ballpark.
4. Talk to your tuner about how much timing you can get, but you're in the right ballpark on 93. Depends on your tuner, fuel, etc.
zaquhree
Orlando
2015 S550 GT
Total spark represents timing added or pulled so don't worry about adding.
93 octane I'd like to see 16* on a street tune and 18* on a track tune
E85 I'd like 20* street and 22* on the track
Whtvans550
Houston
2016 mustang gt
ok thanks guys for the info just really want to learn with this car and data logging with this paxton setup goal is some 10.90s with just a axle back. then add a converter and a e85 setup.
zaquhree
Orlando
2015 S550 GT
I went 10.7@131 with axleback, 3.8" pulley, bmr springs and 93 octane.
No other mods
Whtvans550
Houston
2016 mustang gt
No other mods
wow man those are awesome times would that be considered a track tune 18* with those et times? what were inlet temps, what time of the year was this done? that mph is great man!
