Saw the 5.2 on an engine dyno
10splaya22
CLT
Drew
F150
Here is details on the tortue testing of the 3.5L Ecoboost motor. Pretty amazing what they put these engines though. I would imagine the procedure is similar for production engines. They run these engines many times harder than what the average person would ever put the engines though.
LINK
A production EcoBoost V-6 engine, serial number 448AA, was randomly selected off the assembly line at Ford’s Cleveland engine plant. The dual-overhead-cam power plant was shipped to dynamometer cell 36B in the Ford Dearborn engine labs and run for 300 hours to replicate the equivalent of 150,000 customer miles, including repeated temperature-shock runs when the engine was cooled to minus 20 degrees Fahrenheit and then heated to 235 degrees.
The engine was then shipped to Ford's Kansas City truck plant and installed in an F-150 4X4 crew-cab pickup. It was driven to Nygaard Timber in Astoria, Ore., and put to work as a log skidder, dragging a total of 110,000 pounds of logs across the ground to demonstrate its 420 pounds-feet of torque.
From there, the truck was driven across the country to Homestead Miami Speedway, where it was hooked up to a trailer carrying two of Richard Petty’s Ford Fusion racecars, a load of 11,300 pounds, and run continuously around the track for 24 hours, averaging 82 mph and covering 1,607 miles.
It was then taken to Davis Dam in Arizona, where it bested both the 5.3-liter Chevy Silverado V-8 and the Ram 5.7-liter Hemi V-8 in an uphill towing contest pulling 9,000 pounds up a 6 percent grade on Highway 68.
Finally, the 3.5-liter twin-turbo EcoBoost engine was shipped to Mike McCarthy’s race shop in Wickenburg, Ariz., and installed in his 7,100-pound F-150 race truck. McCarthy practiced locally for 1,200 miles and raced the truck in the SCORE Baja 1000, the toughest off-road race in North America, finishing first overall in the new Stock Engine class after 1,062 race miles.
McCarthy said the engine’s fuel economy was so good compared with his previous V-8 engines that he was able to skip two planned fuel stops during the Baja event, which helped him win the class.
After Baja, the thoroughly thrashed and raced engine was shipped back to Ford headquarters in Dearborn, Mich., and dyno-tested once again. It was found to produce 364 horsepower and 420 pounds-feet of torque, just one horsepower less than its rating and exactly the same output as its nominal torque rating, according to Ford.
A leakdown test was performed to measure how well the engine’s 24 intake and exhaust valves and piston rings were still able to seal the cylinders. One cylinder was found to have a cautionary 13 percent air loss past the combustion chamber’s seals, while all other cylinders were acceptable with single digits of air leakage.
Oil pressure at idle on the dyno was normal, in the mid-40 psi range.
After the dyno, engine 448AA, which had never been opened or inspected, was shipped to the Detroit auto show where, on Saturday, it was torn down for inspection in front of a live audience of more than a thousand Ford engine enthusiasts and their families.
The teardown was narrated for the audience by Jim Mazuchowski, Ford’s chief engineer for V-6 engines. Powertrain engineer Phil Fabien explained the advantages of things like turbocharging, direct fuel injection and twin independent variable cam timing while engine technicians Chris Brown on the right bank and Chris Rahill on the left bank took the engine apart using a pair of air wrenches and hand tools.
As they went, the engine parts were laid out on three huge tables so that when the tear-down was complete, the engineers and the audience could take a closer look. During the tear-down, engineers Steve Matera, Kirk Sheffer and Jeanne Wei organized the parts and made some key measurements.
Valve lash, which measures valvetrain clearance between the camshafts and valves, was checked at 0.17 mm on the intakes and 0.38 mm on the exhausts. That’s well within normal range for both, according to Ford. Crankshaft end play was measured at 0.12 mm, also acceptable.
The timing chain, which controls valve timing and synchronizes engine operation, was still within normal tolerances. With age, a timing belt loses tension, and a hydraulically operated timing chain tensioner is used to compensate for slack. The tensioner has 10 teeth that work like a ratchet to maintain tension. The EcoBoost V-6 used three teeth, well within the timing chain’s operating specs.
We didn’t get a photo of the valves, but they had carbon deposits similar to that found (and seen in pictures) on piston combustion surfaces.
Visual inspection of the cylinder heads, twin turbos, piston crowns, ring lands, rod bearings and cylinder bores by the engineers and your correspondent showed no major signs of anomalous wear after 163,000 miles of endurance testing. The main bearings showed cosmetic grooves but not excessive wear through the metal.
  • Like
Reactions: D K
Hack
Minneapolis
Mustang, Challenger
The original 3.0 SHO motor ran 24 hours at 11,000 RPM's. Just saying......
I would think it's typical of every engine in every production car that they get torture tested near or beyond the redline.
And their lives even at redline by far exceed a racing engine.
Erik427
Huntington
1979 Mustang
Above the stated redline is one thing. But to be ran at 11,000 rpms is a bit extreme. That would not have been done with a pushrod motor.
1320'
Medford,Oregon
2011 Avenger...sadly
It can be done with pushrods, but not for long.
Top Fuel and ProStock motors spin at about 10,000...but obviously for a max of about 7 seconds (PS) and 4.5 seconds (TF FC) respectively
D K
Denver
Popemobile
The other thing about this engine is that it sounds much more like a flat plane at high (over 7k) rpm.
I forgot to put that in earler.
