Sai Li Fuel System Install
joedrt73
georgia
2016 mustang gt base coupe
Hmm. I'm not really sure. You plugged in the new harness to the FP right?
Yes. New pump harness to pump and left original connector outside the rubber housing.
Sai Li said tuner would have to turn off fuel pump monitor in the ECM but the tuner says he's never had to do that. So maybe something has changed in a 2016 model.
Chummel
Tulsa, Ok
2015 Mustang GT PP
Is there someplace I can go to view the pics? They are all broken for me
Chummel
Tulsa, Ok
2015 Mustang GT PP
I just updated the first post with the photos. :headbang:
Thank you sir! And when you say it doesn't come with a pressure gauge, are you talking about the gauge off the regulator? I'm about to pull the trigger on this kit and I'm debating if I want to tackle it myself.
Jay159866
2015 GT 1966 Coupe
Its a very easy install. It didn't come with a fuel pressure gauge for for the regulator. It might come with one now, but at the time it didnt. Sai is a great guy. If you give him a message or call, he will tell you exactly what's in the kit. I think I paid about $26 for an aeromotive one from Amazon. It got here the same day too. :clap2:
Chummel
Tulsa, Ok
2015 Mustang GT PP
Thanks, I have been talking to him on and off. I guess it does come with a gauge now (he just confirmed). Is there any need to run a filter with this set up?
Chummel
Tulsa, Ok
2015 Mustang GT PP
Do I need to depressure the fuel system before removing fuel lines?
Jay159866
2015 GT 1966 Coupe
I think he's against running a fuel filter on this setup. At least that's what I've heard from other people, never asked him about it.
When you take the line off the orginial fuel hat, its going to spray a little. Grab a rag and put it over top of it.
Chummel
Tulsa, Ok
2015 Mustang GT PP
i pulled the trigger on this system and I'm going to attempt to install it myself. I'm sure I will be asking several more questions in the coming days. Thanks for the support.
Jay159866
2015 GT 1966 Coupe
Sure thing! It's a pretty easy install. I think he has moved to different pumps but it should all be the same! Great choice btw. You'll love all the money you saved. :cheers:
Chummel
Tulsa, Ok
2015 Mustang GT PP
[MENTION=18557]Jay159866[/MENTION] do you have the power coming from that middle terminal in the fuse box? Kit gets here tomorrow. I think I have all the other wiring figured out. Thanks
joedrt73
georgia
I can answer that. Yes it comes from the middle terminal.
Chummel
Tulsa, Ok
2015 Mustang GT PP
Does it matter where I put these?
On the fuel pressure regulator, do I need to hook up a vac line or can I just plug it?
Chummel
Tulsa, Ok
2015 Mustang GT PP
Do I need to make any adjustments to the pressure regulator?
joedrt73
georgia
don't plug it if your not going to put a boost reference there.
