You can tap either one. I used the purple before I knew you should tap the yellow/grey and I already had it sliced due to my BAP.I got them to load off the email from the post. You tapped the purple wire? I thought it was supposed to be the yellow/grey or you get the wrench light ?
I did wire the yellow/grey and no wrench light. Thanks for your pics and great write up ....You can tap either one. I used the purple before I knew you should tap the yellow/grey and I already had it sliced due to my NAP.
Go with the yellow/grey for non-continuous priming.
The fuel pump harness wires should be yellow to yellow and black to blue.After starting the car a second time I am getting a cel P0627 "Fuel Pump A circuit open". I have to clear the DTC to get the light off. Them comes back on next restart.
I have the yellow wire (pin 5) which is going to the 2 blue wires. It primes and shuts off but still throws the light.
Any ideas??
