S550 Lap Times (Road Course)
bellwilliam
bellwilliam
Los Angeles
William
17 GT350R
this was a heavy braking track (worst of all the tracks in the west, 3 braking zones all sheds off 75-100mph). at Willow Springs Raceway, outside treads corded within 2 sessions (with -3.5 camber) on a brand new tire. So it is a balance thing, very track oriented.
toe is zero. it is a strut thing with heavy braking imo.
for those thinking -3.5 is too much camber, see here:
https://www.mustang6g.com/forums/showpost.php?p=2232817&postcount=187
While chatting with bellwilliam, he swore by -3 to -4.5 front camber. My data also supports this.
I was talking to Sonny (driver for 949 Racing) and Dan M. (from Ford Performance Racing School) at the private Buttonwillow track day about camber as well, and both echoed William's comments about the car liking a lot of negative camber upfront. Dan mentioned he's been wanting to push the race-prepped GT350R at the school they're building to something like -3.5, but is getting a bit of push back since the car will see joyrides from Ford execs and it's overkill for them.
wmfateam
Arizona
www.facebook.com
Whitey
2017 LB GT PP
Make/Model/engine/trans/packages: Ford/Mustang/5.0/MT82/Perfromance Pack
Track/Course: Bondurant School Track with Looper
Best Lap Time: 1:12.681
Brake Pads: Stock
Tires (Size & Model): Federal RS-RR 275-35/19
Suspension: Steeda ProAction Adj/UltraLite Linear/Sways/subframe all the things
Other Mods: Mishimoto Intake Tube, CJ Pony Parts H-Pipe, GT500 Mufflers
DocWalt
SE PA
GT350
Make/Model/engine/trans/packages: 2017 Ford Shelby GT350
Track/Course: NYST
Best Lap Time: 1:34.595
Brakes: Stock with Raybestos ST43 pads and Motul RBF600 fluid
Wheels: 6GR R spec wheels
Tires : 305/50-19 front and 315 30-19 rear R spec Cup 2s
Suspension: BMR front bar on soft
Other Mods: FRPP air filter
Alignment: -1.8 front (1/16th inch toe out), -1.0 rear (1/8 inch toe in)
Weather: ~55 degrees, partly/mostly cloudy
[ame]
Mattrix
The Engine Destroyer
Michigan
2015 Roush Stage 1 Mustang
Make/Model/engine/trans/packages: 2015 Ford Mustang 2.3L EcoBoost AUTO
Track/Course: Waterford Hills
Best Lap Time: 1:21.263
Brake Pads: Hawk Track
Tires (Size & Model): 285/35/20 Michelin Pilot Sport 4S Square
Suspension: Ford Performance Track shocks, struts and springs. Steeda sway bars etc..
Other Mods: Big Brake and Big Turbo upgrades!!
Waterford Hills Road Racing
wmfateam
Arizona
www.facebook.com
Whitey
2017 LB GT PP
Make/Model/engine/trans/packages: 2017 Ford Mustang GT base w/ PP
Track/Course: Arizona Motorsports Park CW
Best Lap Time: 1:50.688
Brake Pads: Stock Front/WeDon'tLeft Rear
Tires (Size & Model): 275/35/19 Federal RS-RR Square
Suspension: Steeda ProAction Adj/Ultralite Linear/SwayBars
Other Mods: GT500 Mufflers, H Pipe, Mishimoto Intake Tube
Track/Course: Arizona Motorsports Park CCW
Best Lap Time: 1:52.036
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Make/Model/engine/trans/packages: 2016 Mustang GT Premium w/ PP
Track/Course: Circuit of the Americas
Best Lap Time: 1:41.8
Brakes: GLOC R12/R10 pads and SRF fluid
Wheels: Stock PP wheels
Tires : 285/35R19 RE71R
Suspension: BMR front bar on soft, Strano rear bar on medium
Other Mods: Koni yellows, 75w140 diff oil, 4pt Schroth Harness,
Alignment: -2.5 front 0.15 toe out, -1.5 rear, 0.15 toe in
Weather: ~85 degrees
Fastest lap I slowed to pass a Vette which spun out in corner 6.
bellwilliam
bellwilliam
Los Angeles
William
17 GT350R
Make/Model/engine/trans/packages: 2016 Ford GT350
Track/Course: Utah Motorsport Campus East Course, Ford GT350 Track Attack
Best Lap Time: 1:49.734
Brake Pads: stock
Tires (Size & Model): Michelin PSS, 295/35-19 and 305/35-19
Suspension: stock
Other Mods: front camber plate
This was Ford Performance GT350 Track Attack. East course of Utah Motorsport Campus (old Miller raceway). This is the only session you get to go out alone by yourself (first was lead/follow, the second was an instructor in the car). This is a free 1 day school provided for GT350 owners.
I had to set start/stop timer at Turn 6. There was a lot of slow traffic (point by passing only at the front straight), it is next to impossible to get 1 clean lap. As it means you have to not of caught anyone in 2 laps (or if you got lucky and able to complete a pass at the short front straight without slowing). By setting start/stop at T6, I can start from pit lane, and be able to get a clean lap as long as I don't catch anyone in 1.2 laps.
The car is a stock GT350 with front camber plate. Unfortunately, all the school GT350 have a dangerous 4 point harness (non-ASM). Which made me very uncomfortable.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Brake Pads: stock
Suspension: stock
Nice.
But why is your lateral accelerometer reading -0.3 or -0.4 g when you're going dead straight ahead (and getting -1.5-ish in lefthanders but barely over 0.5 in rights)?
Norm
wildcatgoal
@sirboom_photography
TBD
Brake Pads: Stock
Don't the Federali tires not have the appropriate rating for the weight of our cars?
wmfateam
Arizona
www.facebook.com
Whitey
2017 LB GT PP
To my knowledge, the factory tires were a 96Y and mine are a 96W. So same load rating but a lower top speed (186 -168).
dmann
Alabama
2018 GT PP1
I was out at VIR with [MENTION=16015]Bridgie[/MENTION] and [MENTION=30820]DocWalt[/MENTION] this past weekend as well.
Make/Model: 2015 GTPP
Track/Course: VIR Full
Best Lap Time: 2:09.85
Brakes: DS1.11 front/GLOC R12 rear w/ Castrol SRF fluid and AP rotors
Wheels: Apex 18x10
Tires : 285/35/18 Hankook RS4
Suspension: Ridetech coilovers 400f/500r springs + other stuff
Other Mods: GT350 IM/TB, AED tune
Alignment: -2.2 front (0 toe), -1.5 rear (1/8 inch toe in)
Do you know how much downforce you get with your setup? Does it fell balanced?
dmann
Alabama
2018 GT PP1
Make/Model/engine/trans/packages: 2016 Ford Mustang GT base w/ PP
Track/Course: COTA
Best Lap Time: 2:32 via data
Brakes: stock performance package calipers and rotors, Carbotech XP12 front, XP10 rear pads, Castrol SRF fluid
Wheels: Apex EC-7 18x10 squared
Tires : (295/40/18 all four corners, Hoosier R7)
Suspension: aFe/pfadt coilovers and sway bars, stock bushings, links, etc...
Other Mods: Kognition wing and APR front splitter, borla ATAK with resonator, engine all stock.
Here is a video from the first session Sunday Morning warming everything up. There are some 36's and 37's in there:
I took it easy on Friday and saw how the car was going to do. Made some minor tweaks. Saturday was mostly the same. I got sucked into lead follow with a friend on Saturday and his AIM showed several 2:32's. I figured I could warm everything up on Sunday morning and by mid day try for a 2:30 flat. I ran the first session and warmed the car and brain up. I parked the car for only 20 minutes and then went back out. As I just wanted to work on a couple turns. About 15 minutes into that session, I got a "rear axle differential temperature increased, reduce speed" warning. Score one for the 2016 mustang now that they have the temp sensors in the diff stock! My fault, I wanted to see how the stock fluid would do. I'm sure if I would have let the car cool down more between sessions I wouldn't have had the issue. I had a 12 hour drive home, so I decided not to push my luck. Hopefully the warning pops up before you cook the fluid. Diff did fine on the drive home and didn't make any noise so I assume it didn't cook the fluid. Will change all fluids in the next day or two. Thought it was worth mentioning though. My attempt to do a 30 flat will have to wait until next time. Such is life. I still had a blast. :)
How do you like the carbo tech pads?
bellwilliam
bellwilliam
Los Angeles
William
17 GT350R
Op: California Speedway (old name) is the same as Autoclub Speedway (new name) also the same as Fontana Autoclub Speedway.
bellwilliam
bellwilliam
Los Angeles
William
17 GT350R
Nice.
Norm
I think it is because the camera is sitting crooked to the right (CW).
