s550 differential grenaded
dodger789
L.A.
john
2016 gt performance, whipple, stage 2 throttle body, rxt clutch, cf driveshaft, steeda subframe kit, 840 hp axles, X force w/ corsa long tubes and mickeys
I have a 2016 GT pp with torsen diff and need a complete differetial. Any ideas? I want to keep the torsen for sure but no one makes a replacement with 3.55
I found a 2019 GT 350 complete rear end with subframe axels and brakes springs....everything...will this whole rear end assembly fit the 2016 gt s550. I have about 800HP and use Gforce axels.
Jackson1320
California
Jaxson
2015 mustang gt
Why do you want the torsen unless you are on a road course it is weaker and slow. If you are looking for off the line power do not get another torsen get a iron 3.55 or 3.73
Rapid Red
Woodstock GA
Greg
At the very least nix the 3.55........... torsen holds its own pretty well, I'd say. Don't see slow, gear ratio is a gear ratio.
3.73 torsen or solid axle should run the same speed.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
The torsens do break. The Detroit Tru Track is stronger.
dodger789
L.A.
john
Yes, I use it for road racing everyday.... ok, almost everyday.
MRGTX
CT
2020 Mustang GT 6spd base
Are you only looking for complete assemblies? These parts can be bought separately with ease (last I checked). I swapped my 3.55s for 4.09 and added the Torsen while I was at it.
Brazos609
2015 GT Premium PP Recaro
I have a 2016 GT pp with torsen diff and need a complete differetial. Any ideas? I want to keep the torsen for sure but no one makes a replacement with 3.55 I found a 2019 GT 350 complete rear end with subframe axels and brakes springs....everything...will this whole rear end assembly fit the 2016 gt s550. I have about 800HP and use Gforce axels.
Yes, the GT350 rear assembly will bolt right up, same chassis. If you are looking for a 3.55 Torsen you need to look for a differential out of a 18+ automatic PP1 car.
dodger789
L.A.
john
Yes thanks guys. I finally figured out that the 2018 automatic came with a factory 3.55 torsen so I found a wrecked 2019 with only 7,000 miles on it. Probably paid a little to much at $700 but with the tremec transmission the gearing is perfect. I pulled on a Yamaha 1000 2 months ago and there is no better felling than that. Also I finally got the axle out and it was snapped again "inner stub drivers side" If anyone is upgrading axles the ford performance are a step down from gforce outlaw axles and are both made by the same company ford just put there name on it and charged more for less.
dodger789
L.A.
john
Thank you I found one.
