Roush tune blocking recall?
DrewT
Minnesota
Andrew
2020 Mustang GT Premium
My local Ford dealer said they couldn’t install the brake fluid warning update from the recent recall because of the Roush tune that came with the super charger. Is this true? Does Roush need to incorporate this recall into their tune?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Can you flash back to stock tune?
Have dealer pull car into bay, flash stock tune, have dealer flash recall, then re-flash the Roush tune?
Or is Roush a one time flash?
engineermike
La
2018 GTPP A10
This is a common problem for Roush and Whipple cars. The dealers diagnostic machine identifies that the pcm osid is not stock and they hit a road block. The ford system allows you to manually enter what’s needed but many mechanics don’t know how to do it. Someone at Roush should be able to explain the process to the mechanic.
fmc_smt
Cottonwood , Arizona
To perform the recall , the tech just needs to select aftermarket calibration when starting the IDS session. It is easy peasy when someone knows what there doing .
Schnder95
Iowa
2022 Ford Mustang Roush S/N 22-0001 TP
The only thing I had to do is just unplug roush osid and have him plug it directly into car then update then plug roush osid back in and done.
Schnder95
Iowa
It's whatever was plugged into the plug underneath the dash. He juat unplugged it, then upload and plugged it back in. I was not watching him that closely.
Schnder95
Iowa
It's whatever was plugged into the plug underneath the dash. He juat unplugged it, then upload and plugged it back in. I was not watching him that closely. Trying to get grass cut before rain.
engineermike
La
2018 GTPP A10
I think that’s just the device that reads pedal position and speed to supply the info to the exhaust valve controller, and the aldl is pass-through. The osid is the operating system in the pcm.
Schnder95
Iowa
He did mention it was a pass thru so that makes sense now. I just reflashed tune when he was done. Just started it and let it run, but didn't drive it. I didn't notice any issues.
DrewT
DrewT
Minnesota
Andrew
I asked the shop manager if I was out of luck on this recall and any future ones. He said to bring the car back because he believed to have found the update procedure. He claims to have now applied the recall update without affecting the Roush tune. I guess I could drain the brake fluid to see if the warning light comes on now 😁.
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
My solution was to just not have it done. I put tape over the obd2 port with NO! written on it. I have enough sense to know when brake fluid is leaking and I can eyeball the reservoir whenever I check the oil.
Buldawg76
Alabama,USA
2020 Ecoboost Premium, 76 FXE shovel, 77 KZ1000
Just unplug the connector for the low fluid sensor in the side of the MC reservoir with engine running to check for brake warning lamp to come on. The tech should have done this since it is part of the recall procedure to test the lamp operation.
BD
DrewT
DrewT
Minnesota
Andrew
BD
Yes. The service order says that they verified correct operation of brake warning.
