Rough idle, no power, gas pedal doesn't work.
Jmesl8er
Ohio
Jamie
2015 Mustang GT Premium, 1992 Twin Turbo 300ZX
This has happened twice now. When I drive it hard it'll immediately go into limp mode. Starts idling horrible and the gas pedal does not work. I'll shut it off, crank it up ( which takes a couple of seconds) then it starts right up. Check engine light only comes in for a couple of seconds.
E85, CAI, 87mm throttle body, cat back exhaust.
Thoughts
What’s your DTC’s have you extracted them from the dash cluster’s Engineering Mode or using a scan tool?
Here ya go, if you enter Engineering Mode from your dash cluster, you can see if there are any stored DTC’s - I had posted this a while back in another thread:
If you have a 2015-2020 with the ANALOG gauge cluster, you should be able to enter the “Engineer Test Mode” and will be able to see stored DTC’s.
Follow this link:
https://www.mustang6g.com/forums/threads/engineering-test-mode.27581/
If you you have a 2018-2020 with the DIGITAL cluster, you should be able to access the same test mode found here:
https://www.mustang6g.com/forums/th...n-18-digital-dash-old-way-doesnt-work.115231/
Jmesl8er
Jmesl8er
Ohio
Jamie
Follow this link:
Hell yeah, thanks!
Southview
Viera, FL
Herby
2015 GT Premium Convertible
