Reworking voodoo heads
Status
Not open for further replies.
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
Interesting. I will take pics tomorrow of that
I was advised these where voodoos. Maybe you are correct
The voodoo heads have 4 bolts for each of the 2 center exhaust ports. That's ONLY on 5.2 heads. That's the easy way to tell them apart from the 5.0 heads.
Also the valves are larger on the 5.2
The coolant passages are unique on the 5.2 vs 5.0 heads
The combustion chambers are also different on the 5.2.
I'm sorry but I think you have 5.0 heads, possibly boss (road runner) heads.
Voodooo
SE Michigan
Scott
Voodooo
SE Michigan
Scott
And here I have thought these where voodoos
Ford put 4 bolt holes on each of the two exhaust ports. This was done so the assembly workers couldn't put a 5.0 exhaust manifold on a 5.2.
A 5.2 heads has different ports, chambers, valves, valve train geometry, coolant passages. Etc.
Voodooo
SE Michigan
Scott
Don't feel bad. I mean you did an awesome port job!
The heads you have may be boss 302 heads. Those are factory cnc ported also.
Did you pay a lot for the heads?
Kahboom
Kahboom
Cathedral City, CA
2015 Mustang GTPP, Recaros/2014 Explorer Sport 4X4
I'm curious if you can stuff or fit Voodoo valves in coyote heads.
Gremlinsteve
Houston
727 roush
I found the seats in the coyote won't handle much over stock sizing
It can be done yes. But you would shroud the valves somewhat and you might needs to start installing new seats
16MustangVet
North Dakota
2016 mustang 5.0
This is my thought too. The work is nothing short of amazing and done in a short time frame. Should speak volumes about his operation here despite the fact some how the heads appear to be mixed up!
Voodooo
SE Michigan
Scott
5.2 heads on a 5.0 block would be shrouded.
Gremlinsteve
Houston
727 roush
Sure would
I'm not a believer in the plus 1mm ferrera valve In them either
I have some pics showing how the shroud at low lift
Deranged1
VA
2016 GT350
This is what I feel like
LOL. Yes you did a good job on those heads. If you feeling like the picture you posted, I know an easy way you can redeem yourself. Get ahold of some GT350 heads, port and polish the piss out of them, and post before and after flow bench tests. Bam, you are redeemed. :cheers:
Status
