DougS550
- May 18, 2020
- Fishers, Indiana
- Doug
- 2019 GT Premium A10 PP1 Whipple Stage 2
David suggested going with the 2200 upgrade but, Wengerd said after reviewing my data logs he sees no issue with my moving to 16lbs boost from my current 14lbs boost. But: I told David I will tap and run a wire from the two Bosh 540 high output fuel pumps voltage input wire and run to a voltage gauge. I will dyno prior to Spring and monitor the actual fuel pump voltage and cross reference to see what level the pumps operational demand are at with WOT runs.You’re running the KMP 1500 system on E85 @ 900 whp? I want to run 950-1000 whp with a single turbo and when I reached out to KPM to inquire about it, here’s what they told me:
1100rwhp on E85 equates to approximately 1300-1350 fwhp on E85.
All our KPM Fuel Systems are rated ot the flywheel on 93 Pump Fuel.
To achieve the same power level on E85 you require 30% to 40% more fuel supply.
1100 WHP E85 = 1350 FWHP
1350 FWHP plus 30%-40% = KPM Fuel System 1755 - 1890
The KPM1500 Module , even with a voltage booster would not support this level. correctly
You would require our KPM2200 or KPM2700 HP system to properly support your power level.
Both these kits come with Twin direct fit Fuel Modules, KPM PWM Fuel Controller, 9/16 stainless steel direct fit Mustang specific fuel line and Fuel Filter, Complete direct fit wiring.
More information
KPM 2200HP FUEL AND PWM SYSTEM (S550 MUSTANG GT 2015-23) | KPM Fuel Systems
KPM 2700HP FUEL AND PWM SYSTEM (S550 MUSTANG GT 2015-23) | KPM Fuel Systems
Please be sure to reach out on any further clarification or questions.
David
